Running Shock With no Oil
In just rebuilt my Vaterra Halix Suspension and it seems that the oil isn't staying in well (probably because it's my first time). Is it safe to run it with no oil or should I try again?
Thanks!
Thanks!
Try again..probably might not to run well with no oil in shocks.possibly causing damage to your shocks not to familiar with this situation never seen anybody run a Rc with no oil in shocks..
Try grease, it will stay in!
Make sure you didn't gouge up the shaft or anything. Soak the rings in oil or use some grease as recommended.
New shocks will leak at first many times, the O rings take time to absorb some oil and swell. I suggest refilling them and bleeding them properly and it should get better if you didn't mess anything up.
You can use grease or slime on the O rings I thought that's what he meant above... Lol
I will try, I found out that I need an o-ring I will oreder on next time I stop at Hobby Town or just order soon from RC planet!
