gear diffs and old school dirt tracks for 2wd vehicles
I know that the ball diff from what people are saying is ideal, but my question is for those who run on old school dirt tracks with 2wd vehicles and use a gear diff, what oil weights are you using?
By old school dirt, I mean tracks where something like a proline caliber, joncepts goosebump, or even an old school step pin would be the hot tire.
3000wt give or take. This was on loose to mid-grip with Short Course 2wd.
The general rule with a ball diff was as loose as possible without slipping. Obviously a gear diff can't slip do basically as light of an oil as possible without diffing out anywhere or just incessantly spinning one wheel from a stop.
Il say this ive seen the D816 last weekend on a clay/soil mix track and with the gear diff I'm assuming the guy was using 1000w oil.
And it was hooked up fine .
good stuff thanks for the info. I am looking to pick up some more PT Racing oils and I am assuming that there isn't anything "special" about oils that are stated to be shock oils versus diff oils other than the cst value, so some if in some weird world I wanted to try say 700CSt ( I am just throwing that out there), then I can give that a go using the shock oil.
The biggest issue with gear diffs to me is the consistency versus a well built and broke in ball diff.
A ball diff doesn't change unless you change it; it's only as good as it's operator. A gear diff over time will change and degrade.
That's the next stage I'm going to test and compete on an old school outdoor track at the end of april, I use MR33 1000 cts in my D216 on low to medium grip outdoor carpet track, on dirt track I'm going to remove 2 gears.
Some drivers are doing so for instance on the DEX 210F.
Obviously I wish a ball diff was available but it's not , maybe in 1 month or 2 ...or 6, so I think removing gears is worth the penny.
Well, even with the best grease a ball diff need some maintenance around 2/3 hours of practice...
cool thanks for the info. How long would you say should you wait between rebuilds on a gear diff? The dex210F is very quick for diff changes so no worries about length of time to take it out so curious.
Thanks for the info on the 2 gear removal. I read that before and will give that some consideration. What have you seen is the weight difference you go with for oil when running 2 gear versus 4 gear to get same feel? (example: 2 gear I went 5K, same feel on 4 gear was 3K, etc)
I though about using two spider gears in a gear diff on a 2wd wouldn't you have to go up on the diff oil weight ? How do they hold up also ?
I run my indoors on med traction .
I think for 17.5 they should be fine from what I recall someone else saying. I just forget what the "conversion" difference was between 2 gear versus 4 for similar feel. As I am going to try the dex210F on old school dirt, looking to see what options are out there.
Now, for stuff with a bit more pep, I heard that its benefical to go to steel gears which I have.
