Caster and its tunning for performance change.
I've recently come back to this hobby and have read numerous things about the effects of caster change and there seems to be some very different opinions. Even between manufacturers their opinions differ considerably, and one manufacturer in particular has changed their opinion of it between its last two models. Can anybody shed some light on caster change and their reasons why they belive it to be as they do?
...and when you refer to "more caster" I assume that you mean leant back more. Which is the way I always felt it worked,however I think you and I would be in the minority.
Caster can have a big effect. I recommend you doing laps at one setting, then changing it and taking note of the affects for yourself. That's part of the fun.
Here's an excerpt from the Hudy Off-Road Tuning Guide. I keep a PDF copy of it in my Google Drive so I can refer to it when I'm at the track. You can find it on Hudy's website here
I have been reading up on suspension and my understanding is that increasing your caster provides additional camber when you turn the wheel. So with less caster you get less additional camber as the wheel turns - from what Ct America has posted this looks like it keeps the wheel at the correct angle while it is not heavily loaded. However once the suspension is loaded up the camber gain isn't enough hence understeer mid and corner exit.
More caster has the opposite effect, too much camber gain at light loading (when turning in) but much better once loaded up therefore better steering mid corner or on corner exit.
First post so be gentle
Sorry was only referring to lateral load, as in when you first turn the wheel in the very first instance there is no sideways lean.
If you take the additional camber gain from the front compressing under breaking, again it would mean you have too much camber during initial turn in - so less caster helps turn in by adding less.
Similarly when mid and exiting the front lifts, so you loose camber so more caster adds a bit more and gives you the right amount.
I think that's whats happening but happy to corrected.
Less caster would have more weight transfer to the front during braking, which would mean greater traction and thus turn-in under corner entry.
Assuming you are braking into a corner...!
