Advantages of mid-motor vs. rear-motor in a RWD buggy?
I have an Arrma Raider buggy that I use when I want to go fast and corner hard on pavement, but I've started entertaining the idea of getting another RWD buggy for off-road use. (why RWD? I dunno, for the challenge I guess. Also for powerslides.) I was looking at the Durango DEX210v3, and I noticed it has a reversible transmission, so it can be run in rear-motor or mid-motor configuration. I'm quite familiar with the behavior of rear-motor vehicles, good acceleration and good braking, but a tendency to wheelie, but I've only driven one mid-motor RWD vehicle and its performance was pretty crappy. It accelerated okay, but when braking the gravitational-force vector of the transmission tilted away from the rear wheels' contact patch instead of toward it, so it just tended to skid and spin around a lot.
So...in what circumstances would I want to consider running a buggy in a mid-motor configuration, especially if it's going to be run off-road a lot?
are you looking to race with this buggy or just cruise around 'off road'?
More to do with setup IMO. Sounds like excessive droop on the rear, which would have allowed the rear of the car transfer too much weight to the front and you lose traction that way. Same can happen with RM cars
RM vs MM for me is more behaviour in rotation. In a straight line, RM and MM cars just need to have shocks setup properly
Yes, it's a thing called physics. Imagine little invisible arrows pointing straight down from every atom of the vehicle; they represent the force of gravity on the vehicle. When it accelerates, they all tilt backwards, when it brakes, they all tilt forwards, and when it turns, they all tilt to the outside of the turn. More mass in a given location on the vehicle equals more little arrows pointing down and tilting every-which-way as the vehicle moves, and where those arrows intersect the ground determines whether the vehicle will hold its line, oversteer, understeer, wheelie, or traction-roll.
Weight-transfer is the common expression for the physics I described before. We're talking about the same thing.
Yes, that one mid-motor RWD vehicle I drove was poorly tuned, and I eventually sold it because I couldn't get it stable. So, how does rotation differ between mid-motor vs. rear-motor?
A 4WD will drift circles around a RWD if that's what you are looking for.
Mid vs rear will shift the weight balance of the car. Mid is generally better suited for medium high grip. Rear for low grip conditions, there's more weight on the back and less on the front.
Setups can only do so much. Setup is all about weight transfer control but there's a limit to it. You just can't compensate a 200gr+ weight transfer on the back with it.
Tracks with extremely low grip are getting rarer nowadays so most people go with either mid-rear or mid center motor position.
I'm guessing you tried a 4 gear transmission mid motor car? The motor reactions with a 4 gear add to the weight transfer. Suggest trying a 3 gear mid, they have less weight transfer.
The main idea of mid motor is centralizing the mass, reducing the moment of inertia. Less effort to turn the car and less to straighten it back up, responds quicker.
Last edited by Dave H; 01-21-2016 at 12:04 PM. Reason: Polar doesn't apply, wrong moment, my bad
If you look into the b5m thread there is a ton of discussion on this exact subject.
The 4 gear is a better choice for low grip because of exactly what your describing. IT transfers weight to the rear.
The 3 gear is better for high grip , it transfers weight forward.
The team Durango website also has some great animation showing this in action in the 2wd buggy description.
http://www.team-durango.com/blog/201...onfigurations/
A rwd buggy to drift and bash? Then it doesn't matter mid or rear motor but if you are looking into the Dex you will have enough possibilities to try. My experience with the TLR 22 is good overall, liked the traction offered in the rear motor configuration and the mid motor was not far but required one or two changes from the setup hey at least it drifted more than the rear motor configuration.
It was just a crappy truck, that's all.
That also makes sense. I guess the tradeoff is sharper handling in exchange for reduced traction, but if low-grip tracks are rare nowadays then the reduced traction doesn't matter much.
You are correct. In my explanation I was combining the force of gravity and the force of acceleration into a single resultant vector because it's easier for me to comprehend it that way. It would've made more sense if you could've seen the imaginary visual-aid inside my head.
Well, it might not "matter" in the sense that I'm not going to lose a race because of it, but it will still affect the vehicle's handling, so I'm still curious what the effects would be. It makes sense intuitively that mid-motor would drift better, but to be honest I'm not sure I can explain why.
I have a 4 gear MM buggy that has more traction than most RM buggy I've drove. It's comparable to my ex TLR 22 RM because weight bias between the two are similar if not equal. The defining factor is polar moment of inertia, this is the biggest difference between RM and MM and easy to see for yourself if you acquire a convertible buggy.
It does change direction more easily, but it also slides more predictably and less violently, partly due to weight location, partly due to a front and rear suspension that are closer to having balance. Tougher balance to achieve, but theoretically better when done, yeah?
