Team Associated's new RC8B3e >
Like Tree103Likes
Old 05-25-2017, 01:40 AM
  #1171
Hi, on my Rc8b3e i would like to try the arm block block +2 Deg. Have any of you tried them? After putting the new steering block arm to re-build the front convergence? Thanks to everyone in advance
Alex1976 is offline
Old 05-25-2017, 03:25 PM
  #1172
Andybellus's Avatar
Originally Posted by rosko
Jsut finished 3.1e build have to say i was a bit shocked.......fit n finish was excellent.....no binding, no tight diffs etc etc built to kit settings.... great job ae
I will second this... I wasn't missing anything, everything was dialed and went together great. Seems the "plastics" are a bit different than the original no?
Andybellus is offline
Old 05-25-2017, 05:00 PM
  #1173
biggen's Avatar
Is there a misprint in the rc8b3.1e manual the instructions say build the front and rear diffs with the 15mm out drives but it came with 4 17mm out drives and only 2 15mm out drives
biggen is offline
Old 05-25-2017, 05:53 PM
  #1174
bru00z's Avatar
Nitro manual says 17mm Front and Centre and 15mm Rear diff. Makes sense now the CVA's are all the same length.
bru00z is offline
Old 05-26-2017, 01:38 PM
  #1175
Originally Posted by carpetburner
Yes battery was installed in that pic . I put some duct tape on the inside of the body just incase it rubs . I use a fantom shorty 4 cell https://www.fantomracing.com/proddet...?prod=FAN26242 .
All I have are the full size 4s batts. Wonder if all the bittydesign ones will fit those?
Sr9c_Shooter is offline
Old 05-26-2017, 09:45 PM
  #1176
Should work good . The body stays pretty flat in that area .
carpetburner is offline
Old 05-28-2017, 08:06 PM
  #1177
Looking for a Thread on the new 3.1e and cant seem to find one or am i missing it perhaps ???
LOSI 8IGHTE 2.0 is offline
Old 05-28-2017, 08:20 PM
  #1178
Trader Rating: 21 (100%+)
There isn't one. Usually when a car receives "minor" updates, discussion continues in the original thread.
MX304 is offline
Old 05-28-2017, 08:43 PM
  #1179
Mickey_B's Avatar
Trader Rating: 7 (89%+)
Was building my shocks today with the optional Fox Shock bodies and could not get the blue anodized shock body seal retainer to screw on all the way. On the stock shock bodies the seal retainer screwed on with no issue. Anyone else have issues with these Fox shock bodies or have a fix?
Mickey_B is offline
Old 05-29-2017, 01:03 PM
  #1180
This is a great question to anyone who's built both, has the quality been improved? I'd love to know this as I'm thinking of getting one. The thing is though, I thought the rc8.2 was good quality so maybe I'm not a good judge.
Old 05-29-2017, 02:21 PM
  #1181
MX304 is offline
Old 05-30-2017, 01:17 PM
  #1182
Andybellus's Avatar
I had the same issue with a set I installed a few months back. I'm sure this isn't the right way/fix but I added some bearing lube and tightened them down using a cloth to wrap them in and a pair of pliers. I've yet to disassemble so..... proceed at your own risk.
hahah the quality of the rc8.2 was good, but the car design itself left a lot to be desired.
Having built both the old/new B3e's I think it has improved but would like to get others feedback as well.
Old 05-31-2017, 08:43 AM
  #1183
I built my 3.1e yesterday and I've gotta say, I'm moderately impressed. All of the gripes I had about the T3e were fixed on this kit. I love the holes in the chassis for weights! Fit and finish was top notch on this thing!
bru00z likes this.
KCodd is offline
Old 06-01-2017, 11:56 AM
  #1184
Guys, let us know your impressions after you drive the updated kit. Is it worth upgrading from the original??
Old 06-02-2017, 05:42 AM
  #1185
You can buy the upgrades for the B3e.
KCodd is offline
