JQ_Racing White Edition Ecar
#121
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I'll measure the battery tray when I get home tonight and write it here, although I'm 99% sure all commercially available hardcase 4S packs fit without any modifications (except the newer Hobbyking ones, as I said earlier)
#122
djbxp, the battery tray is 145 mm long and 53 mm wide
#123
Thank you very much my friend. That's really helpful since i'm out of home.
#126
I have absolutely no idea what The Wrench is saying.
Anyhiwe, the WE suspension is 100%.different. The only thing that they have in Common are the diffs, diff case, and bearings. All new hubs, shocks, towers, universals, toe blocks and Sway bars.
I think the WE shocks are 100%.necessary. Once you try them you'll never go back the YE shocks. They provide
More pack when jumping and allows more tuning options because of the variety of pistons available. I believe you have to use YE shock shafts with WE shock bodies as the WE shafts are longer.
The YE is awesome indoors!!!! But it would be even better with WE shocks so it doesn't bottom out all the time.
i still run my converted wide chassis ecar, you can get the yellow shocks to work well, i havent really felt a difference between the 16mm white shocks and the 15mm yellow shocks... never had an issue with bottoming out or chassis slap with my conversion...
it helps to run the shock shafts in a drill with some metal polish to really make them smooth and some oring grease like green slime as you assemble
running kyosho orange springs on my ecar's... blues on the nitro.... plush and pretty good everywhere
#128
Is it extremely recommended to run sensored motor / ESC ?
some combos like Mamba Monster offer "waterproof" esc and motor but NOT sensored anymore. Is it much difference on the driving? Is it worth to go waterproof for driving on dusty conditions?
#130
Since the price difference is small (about 10-20USD) I always go sensored for racing applications. I (and may of my friends) regularly race non waterproof combos on very dusty tracks and nobody has any problems. Personally if you don't plan to drive during rain or through water puddles there is no need for waterproof electronics.
PS. there is no waterproof electronics, It would be much better to call it splash proof!
ESC's can really be waterproof, but fans on them aren't.
Brushless motors are not waterproof, that it's if they are running in non-sensored mode they can run underwater (non conductive kind like rain or lake water, not seawater) but bearings will be destroyed very quickly (water washes out lubrication) and rust will start to appear.
Batteries are EXTREMELY DANGEROUS to run underwater. Although the cells should be sealed there is no guarantee that the seal if perfect. Not to mention what will happen with a LiPo if water causes a short-circuit!
Running any RC car in rain or over water is purely for show! You will very quickly destroy your bearings, have major rust problems, destroy your electronics/battery. Look on youtube for failed RC aquaplaning attempts and consequences...
#132
Thank you guys for the input.
What is considered a safe C rating for the batteries to get?
REDS 1900KV didn't publish AMP specs or power... how to calculate?
under same specs is TEKIN RX8, and seems that is drawing 90A under acceleration and 125A under heavy load / braking. So a 5000mAh battery on 25-30C will be fine ? (5000X25=125).
What's your experience what that ?
#133
http://www.smc-racing.net/index.php?...product_id=256
#135
I have not seen it posted yet but the WE E-car setup sheets are available at http://eu.jqracing.com/files/PDFs/JQ...V1.0-blanc.pdf
