New Schumacher KF2
#721
R/C Tech Elite Member
Does anyone else have problems with the ball diff's adjustment bolt (the longer of the two bolts) breaking? I go through one every five minutes or so, regardless of wrecks. The only weird thing I see in the whole procedure is that I have to use a tool to tighten the adjustment bolt. I can't quite get it tight enough by holding the opposite outdrive with my hands. I try to tighten the locking bolt gently as well but it backs out if I don't torque it down. I never had such a problem with the SV and I can't believe there's enough force on the bolt head to shear it off, but it's happened regularly.
My KF2 has some severely mismatched roll couples and upper link lengths (and about 3% more nose weight than anyone else at the track), but it runs well. I just can't keep the diff in one piece.
#722
Okay guys i have a serious delima, I'm looking to get away from my B5M Buggy and race something that every man child and dog races and was looking into a new Xray or Durango carpet buggy but then a friend turned me onto the new Schumacher Cougar KF2. SWEET car so convince me i guess is what i'm asking in why this car might stand out over the XRAY and Durango. thanks for any info and help making my decision hopefully easier.
#723
KF2
#726
You will need to fashion a new brace if you don't already have it. Without it, there is enough flex in the chassis for the belt to skip.
#727
MM
I'm getting 21.5mm chassis/ 17.0mm brace center to center. Now not all calipers are created equal!
#728
That's great, thank you. I thought that they were the same as the other mounting holes spacing and that pretty much confirms it. I'm off to get drilling this weekend. I don't think I 'need' the MM layout as I race on astro, but I like to have the option ;-)
#729
Measurements
That center to center was chassis hole! I think you knew that but wanted to correct my wording.😀
#730
Haha, I cross checked the measurements last night and they work. Luckily, as long as they are square I can use the belt tension for any small adjustments in the longitudinal distance.
Looking at the MM fore/aft weight balance it still looks as if it'll work on astro anyway-thoughts?
#731
Price
Whats the price on one of these in the UK?
#733
MM
#734
It's got to be worth a go! Blowing tyres-that's phenomenal! I raced my RC10 @ SRS in Phoenix and was amazed at the grip. I'd have thought a KF2 would have been amazing in those conditions-more grip than astro. I was blown away by the thought that damp clay could be so grippy.
#735
SRS
