New Schumacher KF2 >
New Schumacher KF2
Like Tree12Likes
New Schumacher KF2
    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech ForumsThread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Old 10-10-2015, 03:48 PM
  #601
Originally Posted by Airlmeier4422
Thanks Riverbluff. Does any one know if the rear config will work with a track that has slight loam and med grip? Basically looking for a new buggy that can run outdoors and indoors..
No.
maizer is offline
Old 10-10-2015, 04:09 PM
  #602
Does the KR do mid motor also?
No, the KR is rear motor only. Yo can get an additional chassic for the KF2 that moves the motor back even further. This makes the KF2 a bit more versatile for low traction situations.
Riverbluff is offline
Old 10-10-2015, 04:41 PM
  #603
Jpdanger's Avatar
The Kf2 has three motor mounting options. There's the standard motor forward, low grip option, and mid motor option. If you're looking for a rear motor option, the KR is what you want. The KR is a separate car from the KF2 and is not convertible.
As far as versatility, if your looking for a car that will work on medium grip, I personally feel the KR is your best option. The standard and low grip options are intended for carpet and turf. They lack the forward traction needed on dirt/clay. The mid motor upgrade option is viable, but in my opinion is a bandaid fix for a car that was not intended to be run on dirt.
You may still be able to find a SV2 on rctech or ebay, but that platform is no longer being developed by Schumacher. I believe Schumacher still makes parts for the Sv2, but it's a matter of time before they discontinue.
Jpdanger is offline
Old 10-10-2015, 08:01 PM
  #604
SV2 is on sale and a smoking deal at $200 Discountrcstore.com
scoobyrs25 is offline
Old 10-13-2015, 08:04 PM
  #605
303slowdown's Avatar
Trader Rating: 24 (100%+)
Has anyone put a different brand front hubs on there car ? I'm sure it's not a problem but I'm not really liking the small and different sizes of the front hub bearings, they seem really small compared to any other car I've owned. Do you have to replace the smaller bearings more often and are they more fragile ?
303slowdown is offline
Old 10-13-2015, 09:16 PM
  #606
Also Is it the mip pucks for the original kf that fit the kf2
Old 10-13-2015, 09:24 PM
  #607
Jpdanger's Avatar
I've only had to replace a front axle bearing only once. I wouldn't chalk it up to being a fault in the car. The bearings are pretty good quality and it doesn't cost a lot to replace. Avid makes decent bearings and they cost about $1/ea.
The KF pucks are what you want for the KF2.
Jpdanger is offline
Old 10-15-2015, 10:05 PM
  #608
I know this has probably been asked and answered in this tread, but I really don't want to plow through 600+ posts.
What is a good starting point for gearing with 17.5 motor? Was thinking 71/34 to start.
Old 10-15-2015, 10:26 PM
  #609
Jpdanger's Avatar
If I remember correctly, I had mine at 71/28, but my track is small to medium size with lots of turns and a few doubles and triples. I'd start there and go higher.
Jpdanger is offline
Old 11-06-2015, 03:44 AM
  #610
I)arkness's Avatar
so any pics on the special edition kf2?
going by the description seems like its a kf2 with mid motor conversion included as one pack, but alloy instead of carbon chassis??
I)arkness is offline
Old 11-06-2015, 07:00 AM
  #611
Trader Rating: 9 (91%+)
Yes.
Basically, this is the ultimate one with all 3 motor options on an alloy chassis.
leongkc is offline
Old 11-07-2015, 04:53 AM
  #612
I run between 71/30 on a 40x75 foot track, and 71/35 on my home track witch is 100x50. Anyone running a kf2 in 17.5 should use a MIP diff with pucks and this RCM slipper eliminator like I have on my car. Both improve the cars speed. Ceramic bearing also help,
maizer is offline
Old 11-12-2015, 06:38 PM
  #613
Default Lockout
What type of spur gear did you use? Also I would have preferred your MM Conversion for what it's worth!
MelKF2 is offline
Old 11-13-2015, 03:29 AM
  #614
I used a Schumacher gear, but a AE with the three holes is a direct fit. By the way ''it'' is worth $400.00 and it is all yours.
maizer is offline
Old 11-16-2015, 07:33 AM
  #615
Xyzzy's Avatar
Trader Rating: 32 (100%+)
Amain has the KF2 (not SE) on clearance for $313 before the usual $25 off coupon, so $287 shipped.
Last edited by Xyzzy; 11-16-2015 at 11:02 AM. Reason: They lowered the price again.
Xyzzy is offline
