kyosho electric offroad
#6226
I gave up wrestling with the kyosho shocks and just put on a set of losi shocks. Only thing I had to do in the rear was use a longer dog-bone as it occasionally popped out as I run quite a bit of rear droop. I believe if you use the 1" rear and .9" front, the lenght will be very close to the kyosho shock length.
Later,
Later,
#6227
One other question. Does the RTR use the same graphite chassis or is it plastic?
#6229
They don't make a plastic chassis for this car from what I understand. I would love to get a plastic chassis for it if one were available.
Kyosho America does there best to keep stuff in stock but they are at the mercy of Kyosho Japan on some stuff. They are getting much better though.
#6230
It's a real shame, IMO. It's flat-out the best car out there. You don't have to have to be a pro and use NiMh to make it go fast. Plus...they barely got their stuff together parts support-wise. The car has been out for 6 months...and it seems like 4 of those months were spent with us (and the shops) all scrounging for parts.
#6232
#6234
Later,
Later,
I hope our winter indoor offroad becomes successful this year.
#6238
Motor weight plays a big role on the deciding factor to add or not to add. In most cases you can get by without adding weights. In cases where primitive regulations enforce a minimum weight then lead will have to be added to the chassis to make up the weight difference but you will still have way more punch over the best matched ‘everready’s’
TrackPower 4900 weigh around 266g versus an IB NiMG 4200 weighing in around 428g. Lithiums are normally 40% lighter than a similar NiMh pack.
#6240
Guys, I have been searching around but couldn't find an answer to my question. So I thought I would try here. What does the spacers under the front gearbox do? I know it raises the kickup or down accordingly, but what does it do for handling? The more level the better the forward bite but less suspension soak or vise versa? If you guys could explain this to me it would be great! Thanks and keep posting, I'll read all I can read on these cars.....
