Yokomo YZ-2
#5161
Tech Legend
Sorry for the late reply.
https://site.petitrc.com/setup/yokom...ort2022052122/
This is the base setup i'm using with the already mentioned changes + 22mm/28mm strokes
The car is extremely darty on the first steering input. Too nervous and reactive to steering. Will make a vid asap.
https://www.rctech.net/forum/electri...tm3-1-a-4.html
Some thoughts based on what you have stated for setup, issues seen, leveraging my own thoughts and what I use a lot for info here:
https://site.petitrc.com/setup/xray/...2_SetupHelper/
In general seems that setup would have a lot of rotation I would think, relative to the surface conditions you are running on. The Yokomo springs also stand out to me relative to the measured rates being very soft in comparison to AE V2 springs. Need to see the surface but when playing with no sway bars if traction was up, it definitely made the car feel unsettled for how I drive. I also for the cal3.1 specifically haven't liked the more narrow arm position versus what is stock setup from the manual.
Looking forward to seeing the vid. If you can post up what are standard tires used for your surface that would be great too.
#5167
How can a 2x1.7mm piston with 20wt oil have too much pack?
#5174
