Yokomo YZ-2
#4486
Tech Legend
On our track, Darts are the fastest (for a few batteries) and you can get away with Cactus. Pyramids will last long but are quite slow compared to the Schumacher tires. My personal favorite are the Nessis, which are very close to the Darts but last much longer. I will have to give the Twin pins a try, but at the moment I don't think it's going to get better than the Nessis. Great tire all in all!
#4487
I don't have any Darts here at the moment, but I'd say they are similar. Nessi pins could be a bit longer, but they are really close. Jconcepts pink compound is in between Schumacher yellow and blue, and seems to be perfect for the overall shape of the tire and pin profile. On other cars I found the Swaggers could have needed a bit more bite, but that did not seem to be the case when I drove the CAL3.
#4488
Tech Legend
yeah swaggers feel like they have less bite to some of the schumacher tires we use for fronts here, enough so that some do slight setup changes when using them because of that. The do seem to be consistent in grip longer.
#4490
I built my dtm3 and ran it last night for the first time at a club race and all I can say is wow. The only thing I change is on the rear inner turnbuckle I ran no washer and 30 weight shock oil all around and this car blows my dtm2 away. I run on indoor med to high bite clay. I let a couple of other drivers try it and couldn't believe how it ran so smooth.
#4491
#4492
The #3 generation definitely has a great basic set-up. Yesterday I headed to Arena33 for some practice, and all I changed was moving the battery a bit to the rear, increasing rear shock oil just a tad (AE 32.5 = 388 vs. kit 350) and tinkering a bit with springs. The RP Dirt greens in the rear seem about to be the same as the kit universal greens, so that was not really a big change, and the RP Dirt front greens together with moving the battery one hole to the rear made it more comfortable to drive while retaining the high amount of steering.
As I am running in a just for fun class with no weight limit, I checked the buggy's weight for the first time yesterday, and it was at 1414 g, with a 4000 mAh Performa battery, fat Highest DT2200 servo and the kit steel arm mount. I wonder whether I should try to push it below 1300 just for the fun of it. With a light servo and the plastic arm mount I should be more than halfway there, add some Lunsford...
Edit: 1349 g with a Futaba 9571 and the plastic mount!
#4493
Tech Legend
be curious what is the biggest gain part folks are seeing? like is it the lower shock towers or the new steering rack, etc. Got a daughter here who is very intersted in rc all of a sudden lol. Have 2 cal2s sitting here and and variety of parts including stuff to do lower towers, could set up one for her with those changes lol
This week may get my CAL3 together.
#4494
I have the opportunity to buy a new, unbuilt YZ-2 DTM2 for a good price, but wanted to know what would be needed/recommended for running on indoor carpet besides a gear diff and sway bars?
Also, does anyone know if parts are being discontinued since the 3.0 came out? Looking on Amain’s site, quite a few parts are listed as backordered.
#4496
They usually don't discontinue parts immediately, at least plastic parts. I am quite sure, you can still parts for the original YZ-2, but newer ones also fit in most cases.
#4498
Completely forgot about that! You'd also want the steel front arm mount and the wider rear arms. The plastic camber link mount is pretty solid, no worries. If you break the top plate, replace it with the sturdy truck version, which is also included in the CAL3 and DTM3 kits.
#4499
The car is also very durable. I have only ever broken a carrier and a knuckle in an entire year of club racing. Even the wheeler holds up just as well. I have only broken a few front arms.
#4500
Tech Legend
funny thing about the wheeler I think the B74 a-arms will work on it. I measured them up ad other than getting the right hingepin sizes, I think they will fit with 1mm of dremeling for the carrier,
In general I usually go alloy on the ball stud mounts. with the new car using the wider front mount those definitely have gotten hard to come by lol. Seen them pop up though a few times.
I general on the 2wd broken only some carriers.
