Yokomo YZ-2
#3707
#3708
any news on dtm WE, when amain will receive first batch?
#3710
When it comes to Shimming I take the thinner type and bow them dramatically and then slip them on so the bowing faces away from the component because it places resistance on 2 points, and in this case, when you close the gear case onto it, it should apply even pressure to both sides and the diff can move slightly side to side without ever going too far. This also prevents binding you can encounter by shimming the traditional way.
I also use this technique on my steering systems so there is zero play and I never have a dead zone where the car can veer slightly to either direction. On my cars straight is straight.
Not sure if you guys can picture it but if enough people want I can put together a diagram later.
#3711
Due to the new Schumacher Cactus, Eos carpet and hard slipper setting, we are seeing some other strange things. We do have broken diff gear axles. These tend to break at the machined part of it.
When using only 2gears, we use a cut hinge pin instead.
Maybe your is brokentoo.
#3712
2 gear diff?
thanks guys. Will check that out. Any alternative to takign two gears out for more rotation? lighter oil perhaps
#3714
Thanks. I took it apart again and was able to identify more shims were present that stock/ manual suggests but managed to get one more in on the one side of the outdrives so we will see if that helps. thanks.
#3718
When will the cars be available? Everything 2wd is either out of stock or discounted?
