Gearing recommendations for boosted 17.5 ST?
I currently run a AE T3(2.40 internal gear ratio) from back in the day and it's still very competitive. I just started running a 17.5 Killshot with 40* of can timing, geared at 75/26, but in blinky mode. I would suspect you want to start with just a tad of boost and work your way up while keeping a close eye on your temps. If I'm not mistaken, you'll have to reduce the can timing when you increase your esc boost timing. What esc are you using? I using the HK Xcar 60amp esc.
what gearing would you guys recommend on a 17.5 associated b4.1 with 40* boost, 10* can, 5* turbo? I was thinking 26/72? 26/76? using a tekin rs esc and speed passion v3 17.5.
I was running a 33/72 with 20* boost, 10* can and 0* turbo... and it barely got warm after first qualifier and i could hold my on hand on the can no burning. Thanks in advance
