need help with a slipper clutch problem
So when I was racing this past weekend I kept blowing spur gears I realized that as I was racing the nut for the slipper was tighting itself to the point were it would just blow the gear I went threw 3 gears in a matter of 10 mins of race time I made sure my mesh was perfect as well as the right amount of slip and make sure everything was together right what can be causing this problem I can't figure it out it's a kyosho sct please help
I had a similar problem on an Associated B3 (long ago). What was happening was the thrust washer had developed internal friction to the point that when the slipper slipped, it would turn the slipper spring, which in turn rotated the nut to a tighter position. I replaced the coil spring used for the slipper with a stack of belville washers (cone washers) in alternating orientation so they could not transmit torque from the slipper thrust washer to the nut.
Got a feeling there is a lot of glaze on them or groves pads that will do it also. Than you have to tighten it quite a bit to stop the excessive slipping.
+ on the glaze just to be sure. A new nyloc style lock nut couldn't hurt. For the gears, positive you have the correct gear pitch pinion? There are some metric vs imperial pitches that are just close enough to appear to work, but don't very well.
I just had this happen to me a few weeks. During a quick rebuild of the transmission I somehow forgot to put a tranny bearing in and it was causing all sorta of binding and heat problems. Sadly enough it took 2 spur gears to realize that something was wrong.
Yes I will double check to make sure I have the. Correct pitch pinion I am almost 100 % sure I do though will replacing the spring and nut help everything else is new on the slipper
Ok thank u I will have to inspect the plate that's one thing I didn't change on it
