Mugen MBX7R Eco thread!
#751
I would look at your current limiter settings, I did this in loose conditions the other weekend and it made a huge difference. The little bit below is from Randy Pike's RC Blog (he's the team manager for Tekin)
Current limiter is a setting that allows the esc to ease the power being applied to the motor. If your CL (current limiter) is at 100 that’s considered “off” and no CL will be utilized. At 80, you’re getting 80% of the available current applied to the motor. Now if you have a condition where the car is simply too powerful at the lower parts of the throttle, current limiter is your adjustment. It can help control wheel spin, wheelies, and just too much power overall. CL does NOT limit top speed, it does however smooth out the power at the lower stages of throttle.
#757
Thanks for the help i adjust it too 40 percent too see how it go's then
#759
Another new MBX7R Eco owner chiming in. It's my first true e-buggy kit & Mugen product, and I have to say...it was a pleasure to build.
I do have one question. For those of us looking for a bit more acceleration, would it be advisable to run the optional 42/12 gearing? I'm currently running 16t pinion with the stock 46t spur.
#760
42/12 gives you a FDR of 11.83 I believe. 46/16 gives you a FDR of 9.71 I wouldn't change the gearing. I would go up in center diff fluid before I went to that gearing. You will have a ton of pop off the line but top out in 10 ft. I run 46/16 and if I'm not careful I will really overheat, I just run 7k in the center and have plenty of rip. With the gearing of 42/12 your motor will hit top end and heat will come after that. Going thicker in your center diff is quick and risk free of melting down a motor.
#762
