Mugen MBX7R Eco thread! >
Like Tree29Likes
Old 03-14-2015, 01:05 PM
  #421
jannedwr's Avatar
Just started up my new "MBX7R Eco "white power G2" edition!
This year itīs getting even whiter!
jannedwr is offline
Old 03-14-2015, 06:31 PM
  #422
joykiller44's Avatar
Originally Posted by Gpeters66
Got a question about running the underdrive gearing in the rear. Do I adjust the weight of my diff fluid or do I still run the same weight oil. I currently run 7-7-3.
how did you like the underdrive I was thinking of getting that setup myself please let me know what you thought and if you drive on an indoor track thank you Tom.
joykiller44 is offline
Old 03-15-2015, 07:15 AM
  #423
Gpeters66's Avatar
I haven't got the gears yet(should be here next week) but I'm still running indoor right now with a lot of traction. I'm not going to run the under drive gearing until outdoor season starts up, pending weather, in about 2 weeks. Right now the track is a swamp.
Gpeters66 is offline
Old 03-15-2015, 10:03 AM
  #424
CALABASH1950's Avatar
Originally Posted by rcgod
Mugen recommends going up in center diff fluid. I just got mine to try next weekend but I'm keeping the 7k and see how it feels. If it diffs out too much under acceleration I'll go to 10k
What do you mean "if it diffs out too much under acceleration?" I don't know or understand the impact on how different diff oils affect the car. Thanks.
CALABASH1950 is offline
Old 03-15-2015, 10:31 AM
  #425
rcgod's Avatar
Trader Rating: 33 (100%+)
The gears in the rear will spin the rear wheels slower than the front. If the center diff fluid is not thick enough most of the power under acceleration will go to the front wheels. If you have ever seen a buggy or especially truggy accelerating and the front wheels are balooned up and the rears aren't, that's diffing out. It accelerates front tire wear and hurts acceleration.
rcgod is offline
Old 03-15-2015, 08:13 PM
  #426
Anyone running CSI pistons i have the blue v-port pistons I'm going to try what height shock oil and springs should I try for indoor? ? Thanks Tom
Old 03-16-2015, 10:50 AM
  #427
Motorman007's Avatar
Trader Rating: 89 (100%+)
Anyone Try Drake 10f 10c 7r diff setup
and 1900kv and the 15 pinion 44 spur?
If so what is your take on.
Thank you.
http://www.mugenracing.com/content/S...DNC%202015.pdf
Motorman007 is offline
Old 03-16-2015, 11:14 AM
  #428
Waflet's Avatar
Trader Rating: 35 (100%+)
Thank you.
Hideeho
I see really stiff springs, really soft shocks, minimal camber gain in the rear, & tons of rear camber (at least tons more than I run). My guess is he increased the rear dif because it would dif out on sweepers & coming out of corners. He then raised the others to compensate. This is purely a guess though, I haven't run the setup.
Waflet is offline
Old 03-16-2015, 11:46 AM
  #429
hairymuffin's Avatar
Trader Rating: 105 (100%+)
Thank you.
I have mine pretty stock and its excellent,I never liked running anything over 7k in the center for ebuggy...I think he was making a lot of changes every round at the dnc..He has minimal time on the car...Im eager to see what he comes up with once he has more time on it..im more curious on his nitro
hairymuffin is offline
Old 03-16-2015, 11:48 AM
  #430
jannedwr's Avatar
Allmost ready! Only chocks to finish!
jannedwr is offline
Old 03-16-2015, 02:03 PM
  #431
Thank you all.
Other question is it worth it to get 100 packs? Or just stick to the 70c
Old 03-16-2015, 03:41 PM
  #432
Fast410's Avatar
Trader Rating: 47 (100%+)
Any one try lighter shock oil in rear shocks with stock set up ? Rite now I have 550 cst in front and rear , it seems lazy in rear to me , maybe its the stock springs . I run on indoor clay track in winter but will be outdoors in the dirt/sawdust mix soon.
Fast410 is offline
Old 03-16-2015, 04:03 PM
  #433
I ran mine yesterday. I ran it with both 6500MAH SMC packs and 4600MAH SMC packs. on 1900KV motor with a 16T pion and 46T spur gear. The 4600MAH packs are about 6 oz. lighter, and with this pack it seems the springs are to stiff. It handled bumps much better with the 6500MAH packs. I think the car accelerated better and felt a bit more nimble with the 4600MAH packs. It was plenty fast. Before I get crazy changing everything I order some softer springs. I am going to see what that does.
Al_T is offline
Old 03-16-2015, 04:46 PM
  #434
egobrkr's Avatar
Trader Rating: 29 (100%+)
I ran the m2c brass chassis weights this weekend with great success. I saw drake was running 40g in the rear so I ordered some. Was able to accelerate much faster out of a corner and seemed to fly better as well. The only adverse effect I had was adjusting the rear ride height. Love the weight in the rear and don't think I will try the under drive gear now.
egobrkr is offline
Old 03-16-2015, 05:38 PM
  #435
rcgod's Avatar
Damn I'm out of the loop. I didn't even know Drake switched to Mugen. Where is his setup posted?
rcgod is offline
