MBX6 vs MBX7
MBX6 vs MBX7
I have recently bought a mugen MBX6 E buggy. I am curious as to what parts are interchangable, and is there anything i need to be sure to upgrade or replace on the MBX6? thanks
Replacements just bearings , lower front arms, shock bushings , springs . Upgrade about the only thing you really need is a alum steering saver top piece , alum servo horn , alum rear hubs or M2c lead weights for the rear hubs .
i wouldnt use the rear alum hubs,you will keep bending your hinge pins..i have never broken a rear hub,since the x5 was out..other stuff mentioned are good upgrades..alum bellcrank maybe/maybe not? i have plastic and aluminum on 2 cars...plastic one holding up for years
#1 upgrades and maybe the only upgrades needed is the rear toe block....
from the x7,you can use the upper front arms,i installed the front/rear ring/pinion diff gears and it gave a ton of steering
The Alum saver top piece will give you a better steering feel and when you are on power it points the wheels straighter .
Harrymuffin : no mods to use X7 upper arms or the ring and pinions on the Eco 6 ?
