Need help identifying "mystery" center diff...
This weekend I was taking my new to me D8T apart to rebuild the diffs when I ran across the center diff that doesn't appear to be anything Hot Bodies has ever made. From what I can tell, it looks like an Associated diff - but I'm not sure.
Here are the questions: 1) What diff do I have? 2) How does the mystery diff compare in strength to the stock D8T center diff with hardened gears? 3) Is the mystery diff supposed to have a set of o-rings on the outdrives? Here's a couple pics: http://i429.photobucket.com/albums/q...laZR/Diff1.jpg http://i429.photobucket.com/albums/q...laZR/Diff2.jpg |
Looks like an AE diff to me.
yep. probably used it because they can be really cheap to find.
How's durability compared to the HPI diff with hardened gears?
Durability is pretty good. There should be some orings in the outdrive grooves. Use pn 89121 for the oring kit. Put some black grease in the groove, then install the orings, then wipe the excess grease around the top of the rings and outdrive shaft.
Thanks. Also, one of the screw heads is stripped. Any idea if these are 4-40 or metric?
metric
Thanks for the help. So it seems like there's no need to rush out and get an HPI diff?
| All times are GMT -7. It is currently 08:26 AM. |
