Best Bullet Connectors >
Old 06-08-2014 | 09:46 AM
hlpressley's Avatar
Default Best Bullet Connectors
What have you all found to be the most reliable bullet connector? Looking for something that won't come out during a race (including 1/8 scale) but at the same time some that can be removed without using a tool. My experience has been they are either so loose they will come out during a race or they are so tight you can't remove them by hand.
Suggestions?
hlpressley is offline
Old 06-08-2014 | 10:22 AM
the incubus's Avatar
People complain about the bird cage connectors but I have yet to have any issues with any of the 1.5 dozen I have. Having said that, the solid bullets are superior.
The shorter ones here are one of the best for sure: http://www.redrc.net/2011/07/tq-wire...et-connectors/
These are my personal favorite because it captures the wires well and gives you something to grab onto when you need to disconnect them which is a bit of a pain with the low profile ones: http://www.nitrohouse.com/4mm-Bullet...-4_p_2404.html
I've heard these are really good too but I've not tried them myself: http://www.hobbyking.com/mobile/view...dparentcat=409
The Reedy ones look good as well but I've not tried it. Their wire looks really nice too: http://www.redrc.net/2013/11/reedy-p...rs/#more-74432
Hope this helps.
the incubus is offline
Old 06-08-2014 | 05:18 PM
lewis110's Avatar
IMO you really want it to have a nice tight fit. And should be hard to pull out. It also depends on what batteries you are using. All the female bullets aren't the same size. My SMC bullets fit the SMC extremely good. Where the SMC bullets don't fit my Vant batteries at all. They are real loose on those. I've found if the females are on the tight side the SMC is the best. And if its on the bigger side the Schuur Speed male bullets are tuff to beat.
lewis110 is offline
Old 06-08-2014 | 10:43 PM
For 4mm the best are QTEQ.
http://www.reflexracing.net/QTEQ-4mm...ana_p_999.html
PROMODVETTE is offline
Old 06-09-2014 | 12:14 AM
vandalzzz's Avatar
Have no troubles with mine EC5 at 1/8 ebuggy, very easy to solder, very tight (sometimes way too much) and can be soldered within 8AWG wire if needed.
vandalzzz is offline
Old 06-09-2014 | 01:17 AM
Pulse_'s Avatar
EC5 are the best in 1/8
always wondered why people are still using deans in 1/8
Pulse_ is offline
Old 06-09-2014 | 01:19 AM
malcnz's Avatar
+1...deans are a bit borderline for 8th...EC5 all the way.
malcnz is offline
Old 06-09-2014 | 05:15 AM
BashemSmashem's Avatar
Agreed ! Been using EC5 connectors for a couple of years now and would never use anything else again. .......
BashemSmashem is offline
