Motor boost from esc vs can timing.
So today, I was talking to a guy at my local track. He said that he dials out the can timing on his motors all the way to zero. He then uses his ESC to add boost timing in without any motor timing and gears as needed.
I used to just leave my boost at 0 in mod class and turn it up on the can. I was told by using the method I detailed above it would provide a much smoother motor.
Anyone else use this method in mod class? 7.5-8.5 turn motors.
If the track is big enough to run WOT, the turbo function (esc boost) is great. On smaller tracks where you may have only one portion of the track that is long enough, it may not help you as much.
Plus, with can timing, you constatly have it. I'm not sure about some ESC's but the Tekins require you to be at full throttle for a set amount of time before that boost licks in. 9 times out of 10, Im 3/4 of the way down the staright on our last layout before it maxed out. But it didnt help me though thru the other 7/8 of the track.
In general esc timing is more effective than can timing when compared directly.
I don't use Turbo in offroad ever simply because we're not as consistent on the track with throttle "timing" on the track layout as the are in onroad due to traction, bumps, etc.
You would need to test this on your esc/motor setup to see if works for you.
I run an R10pro Orion. I never use the turbo option with mod, but I was told to max the boost on the esc and turn the can to near 0 because it was much smoother. How true is this? This came from a Tekin sponsored driver btw at my local track.
Max boost? LOL No that will not be smooth.
I know alot of people don't but I do like boost. 13.5 boosted in a buggy is a great setup. It's just as fast as a mod motor but you can make the bottom end a little softer.
So with a 7.5 Tekin or 8.5 Orion, which I use in mod class 2wd buggy, what would be the best setup? Straight can timing and 0 timing on the ESC or a mix of both? I run on two decent size indoor clay type tracks.
The guy at the track that told me put the can to zero and turn the boost way up with 0 turbo swears by it. I just want to find out what's the best way to setup the mod motors in those turn ranges to get solid performance throughout the range low to higher RPM. I don't need a ton of high end RPM since it is indoors, but it also does have some straights.
i was told to use the can timing for bottom end ( torque ) and use the speedo for top end ( max speed ). I use the manufacturer recommended gear for the motor. Set the can to 0 test is out. If i need bottom end advance the timing on the can, if i need lees i retard timing. Then i work on the longest straight, setting the esc to where it kicks in where i want it to. Then i adjust the gearing if necessary. Not saying that is the correct way, but for me it works pretty well.
