Ceramic vs Tungstan Diff Balls
#16
R/C Tech Elite Member
http://www.youtube.com/watch?v=JkJwc_lZbyU
As for the amount, watch the videos.
As for how to sand diff rings, the easiest way to to buy Bfast, the harder way is to use and outdrive + sand paper. Try searching "rc diff sanding" and see what articles come up.
#17
To add, tungsten and ceramic (more so..) diff balls can last a very long time because they are harder than the rings. I rarely replace balls, just rings after a few refreshes. I don't even know how old the tungsten balls in some of my cars are.
#18
For the OP
Ceramic offer better performance and they will not ever wear or flat spot like the steel or carbide.
Just one bark from your diff and the steel will be flat spotted and need replacement.
Advise to replace the carbides for ceramic & use the steel or kit thrust for your best performance & durability.
Instead ?
Read up on breaking in & setting the diff.
Also do same for slipper adjustment.
Tip
Use Ae clear silicon grease
Instead ?
Tip
#19
I find that the Carbide balls are easier all around. The cermamics are harder to adjust and do not last as long. Running stock, I only run stock, I can go several months on a diff. I rebuild as neccessary even if its a week or day later. Kyosho supplies tungsten with their kits and they last forever.
I never reuse anything in the diff. If you are going to rebuild it its crazy to not just replace everything....if the thing is chirping like a canary are you really going to reuse the diff balls?? The only thing that I have been ok reusuing are the Avid caged thrust bearings. Those seem to hold up pretty good.
This is just my opinion. There are probably several ways to do all this that would work. To each his own.
#20
I wish more people would realize this.
I like ceramic diff and thrust balls myself.
Here's a diff building by one of the Tamiya factory drivers:
http://www.youtube.com/watch?v=YOMu6Fu3orI
#23
Been using the same set of ceramic diff balls for 2 years now.
every 8 weeks I replace the outdrives due to being hobbed out from wear .
Diff is always smooth and in good condition the life of the drives.
Just try to convince me carbide is better.lol
Personally don't even know anyone that does not use ceramic.
They do not flat spot ever and stay round & smooth.
Carbides??? Not !!
Adjust the same as carbide , no differences.
Remember to break in ..
its your money , after you replace a whole bunch of carbides add it up and see ceramic is your best deal.
Carbides??? Not !!
#25
I would check like every 10 runs and change it when you see the balls wearing down
#26
Cherry , talk to anyone who races 1/12 ............. You cannot get ceramics loose enough to have good feel on the track , without it slipping like mad. Carbides can be run looser than ceramics. And steel even looser yet. This is a fact, not simply an opinion. Ceramics are harder and have a less pourus surface area than carbides or steel . I wish this weren't the case , the weight savings from steel to ceramic can be measured as a % in a 1/12 pan car.
#29
I personally use Adamantium diff balls and vibranium thrust balls!
I know a guy who knows a guy...
But seriously, I use Ceramic Diff balls and Ceramic thrust balls, I have a source and buy in bulk... Just got an Avid caged thrust (ceramic) and I am impressed so far. Allows me to run a bit tighter diff without worrying about failure!
I also do not sand my diff rings!
