Slash 4x4 1/10 Brushed?
I just finished throwing a 4x4 Slash together from spare parts, and used a spare XL-5 with a T12 550 brushed motor system I had lying around. The motor and ESC work great until I attempt to seat the pinion to the spur gear. Then it REFUSES to drive the driveshaft or axles at all.
Is it possible that the XL-5 system is just not strong enough for a 4x4? I have no problem buying a brushless if need, I just want to make sure this is my problem.
Thanks in advance.
Thanks in advance.
It wasn't rolling. I had the motor out in order to juice and test it. I had a feeling it was to weak when I noticed they use that motor in the 1/16th scale... and here I am trying to push a 1/10 scale!
What if I went with a 1/8th scale?
Castle Creations 1/8 MambaMonster 2 + 2650kV. Or even the Castle Creations Sidewinder 8th + 2200kV. It is waterproof which I like for bashing where ever I want. It is built for larger vehicles so it should handle a heavier truck with larger wheels correct?
Did some more thinking and tried to do more research. Apparently Castle Creations themselves think that the Slash 4x4 is a bit heavy for the SV3 SCT combos. I do also have MT wheels that I was hoping to bash with.
/hobbywing sc8 esc and 1/10motor of your choice and be done.
Here, I'll do some work for you.
ESC: http://www.hobbyking.com/hobbyking/s...dProduct=22632
Motor: http://www.hobbyking.com/hobbyking/s..._Inrunner.html
Or another:
http://www.rcecho.com/HOBBYWING-EZRU...mbo-ME176.html
Or this, if you wanna go cheap:
http://www.hobbyking.com/hobbyking/s...arehouse_.html
