Hobby Pro USA PRST1 2wd Stadium Truck
#152
I am really excited to get the truck (and the buggy) outside this year. I normally don't change much on my setup besides tires. My truck has been ballistic inside...as long as I pick the right tires it should be no different outside.
#153
Another great day with the truck. Won the A, and turned a lap almost as fast as the mod buggy winner! The fast guys in buggy were running fast laps around 13.5 seconds, I had a 13.7 and a 13.9 in the truck main.
As far as durability goes, the last few weeks have been really good. I broke a rear turnbuckle 2 weeks ago and went ahead and replaced all of them with Lunsford Titanium ones. I also broke a plastic rear hub in a qualifying heat last week. The CF gearbox brace has been great so far...no transmission case breakages yet. I think if I got the aluminum rear hubs the truck would be indestructible!
#154
#155
I can, but it looks just like the pic you posted in the buggy thread. I use the buggy wing mount in the rear for the truck so I have the same issue with there not being enough room to put the nut on the end of the long wing mount screw. It hasn't fallen out in either the buggy or truck...I think the brace covers the screw head just enough to keep it from coming out.
BTW, I just sent you an order for some more truck wheels...time to mount up some outdoor tires!! Thanks for getting my recent orders out quickly!
#156
#160
Well I tried mine in MM outdoors and it wasn't very good. I tried 2 different types of tires (ones I used before on my Durango ST, I just remounted them on HP wheels) and all night I was having rear traction issues. There was a T5M running against me who said his truck felt great, and he was on ss dirt webs, which I do not have (I have them on order with the LHS, but they are backorder. I think I am going to try it in rear motor to see what that does.
#161
Couldn't find a specific thread for the SC201 and was wondering what spares should I keep in my box. Getting my list together
Tires: I have a box full of Slash rear offset and was hoping they will work ?? If not what fits ?
Thanks in advance
Thanks in advance
#162
If you have the $ get the following upgrades:
-carbon fiber transmission brace (you will not break the gearbox then)
-pro steering blocks (consists of 2 separate part nos.)
-3mm machined motor plate (stock one will bend in RM, MM you would be fine with the stock one)
-aluminum front 0 degree castor blocks (I have broke the stock plastic one on my truck, my buggy ones have held up fine, this could probably be optional)
Once you do those things my HP stuff has been pretty indestructible.
#165
Rear hubs, front caster blocks and spindles (those are sold together in a single pack), ballcups, turnbuckles, gearboxes.
