preload shocks
preload shocks
a friend at the track was having a discussion with me about springs/shocks and he was telling me there should be no preload on the spring of a properly setup car. Was he right or wrong?
If I understand correctly, that is wrong, at least for an offroad car.
If the car has no preload sitting at ride height, then the spring will unload as the car jumps, the suspension would be ineffective for a bit on landing. Would require a much stiffer spring to prevent excessive bottoming that would compromise the suspension in the bumps.
The drastic change in spring rate would likely have other weird effects in cornering and bumps I would think. For example when part of the car is lifted by a bump or turn, the other wheels would not have spring force pushing down to force the wheels down in contact with the track. Or for a wheel going over a depression, etc.
To add, the amount of preload applied to the spring has no bearing on whether or not it's the correct rate spring.
what i understood from him is- if a shock is in its full droop position ie unloaded, it shouldnt have a pre load from the spring. Just repeating what he said.
i understand if a car is sitting on the track the springs are obviously under a preload
He clearly does not understand suspension dynamics. Preload is ride height basically. Far more important for real vehicles such as motorcycles.
Like everyone is saying, no.
