NEED HELP 1/16 e-revo
im new fairly new to hobby still and got a used 1/16 e-revo and want to know more about how to gear them and what not i got a friend i got a tenbol motor mount and transmission with robinson racing gears i believe is what he said but want to know whats best kinda transmission to run if im running only 2 and 3s lipos and what not any help and information will be appreciated thanks alot
thanks everyone u guys been a big help......................................
Wow dude chill.. No one will respond if you act like that. You have given it just over an hour for people to respond..
You may also get questions quicker if you post in the relevant section, the Micro and Minis Forum found here:
http://www.rctech.net/forum/micro-mini-scales-115/
As to your question, the gearing depends entirely on what motor you are going to run..
The stock gearbox will hold up just fine, it's the diffs you need to be careful about.. Pull them out and shim them to remove any slop or you will be stripping gears like there is no tomorrow..
