tekin hotwire 2.0
And no more need for otg cable has it built in just plug and play with micro usb
31.99 amain cheaper than the gen 1
Tekin keeps bringing top of the line stuff to the table its awesome to see
Yeah those are pretty expensive for what u get
Any idea what are the other advantages minus the andriod part since i am not using an android phone over the current hotwire?
what do you guys think?..to maintain the current hotwire or is it better to purchase the newer one?
i guess we have to move with time..but again, can the current one serve the same as it has served us for the longest time?
cheers!
cheers!
Yeah it looks like its all backwards compatible
Looks awesome looks like release date 02/18/2014
Yeah deff go check the spec's at teamtekin u can share back and fourth data between racers and it will data log there is a bunch of other features oh has otg built in now u only need micro USB
Has anyone used the Tekin Data Logging with the Reedy Mach 2 motor? I was trying to use the logger with the Reedy and it does not seem to work. Not sure if I am doing something wrong or it just does not work with it. I am using it with a Tekin RSX esc. It shows the temp in negative numbers.
