Kyosho Ultima SC6 Thread....... >
Like Tree9Likes
Old 07-11-2014 | 10:32 PM
  #331
KalEl63's Avatar
I have finally go the car finished with all the electrics now in.
I decided to start at the 4x1.3 pistons all round with 35WT front and 30Wt rear so I'll see how that feels.
What ride height are people running on these?
I was aiming for 30mm front and 29mm rear but I cannot get the nose down enough without the front springs being able to pop of the bottom collar when no load is on them (eg jumping).
KalEl63 is offline
Old 07-11-2014 | 10:36 PM
  #332
Suspended
I'm doing 30 30 ride height but mines keeps nose diving can't get it to jump straight I hope you don't have that issue I know of this one other guy who haves same issue but I said he just adjusted his driving style a little by holding the throttle on the jumps
FemaleRCfan is offline
Old 07-11-2014 | 10:49 PM
  #333
KalEl63's Avatar
that's interesting as I felt with everything in it, it was weighted well to the rear (I have done the split weight in it yet) but driving is another thing so I'll see how it feels once I finally race it. (just need the rain to go away)
I set my battery in a more rearward position so that maybe also why I can't get the front down as it needs a little weight on the front
KalEl63 is offline
Old 07-12-2014 | 02:27 AM
  #334
Tom Mackenzie's Avatar
My ride height is 30 front and 28 rear. My battery is about 5 to 10mm more forward than yours and no problem on jumps etc. i had loose front springs also to begin with but not anymore. Seems that after about an hour on the track it has settled in and doesn't happen anymore.
Tom Mackenzie is offline
Old 07-12-2014 | 03:26 AM
  #335
KalEl63's Avatar
Cheers Tom I think I might actually move it forward to the next hole and see what it does and that can be my starting point.
KalEl63 is offline
Old 07-12-2014 | 11:39 PM
  #336
Maybe look at your drag brake setting on the speedy. The more drag brake, the more the truck will want to nose down over jumps if you release the throttle. Obviously the higher the drag brake the more tendancy the truck will want to nose dive just as if you push the brake to nose down mid air. As for not jumping straight, maybe a shock has some rebound issues that causes uneven dampening off a jump. Try bleeding all shocks again and check rebounds left to right shocks, should be as close to same as possible.
Old 07-13-2014 | 07:42 PM
  #337
darkstar1974's Avatar
I was thinking of trimming those bulkhead tabs so I could run a long pack all the back under the bulkhead. I'm always looking for more traction. After reading some posts, I'm wondering if that will cause it to jump nose up.
Anyone doing this?
darkstar1974 is offline
Old 07-14-2014 | 02:15 AM
  #338
KalEl63's Avatar
You might find it could push if you move the weight too far back.
Mind you I haven't had a chance to drive mine so it's only a guess it may well work.
KalEl63 is offline
Old 07-14-2014 | 06:51 AM
  #339
Ducky162's Avatar
Anyone doing this?
Josh I run Esc all the way under the rear shock tower. I trim those tabs and run the long pack flush against the esc and use a battery holder in the front. Works really well for me
"Ducky"
Ducky162 is offline
Old 07-14-2014 | 10:36 AM
  #340
dominick i.'s Avatar
Suspended
Josh,
just mount the esc under the shock tower and the battery right in front of it..
it should work just fine.
btw, which servo horn is everyone using? the servo saver that comes with kit looks cheap.
dominick i. is offline
Old 07-14-2014 | 04:56 PM
  #341
Glen H's Avatar
Is the chassis/wheelbase on the sc6 longer than the scr sp?
Glen H is offline
Old 07-14-2014 | 09:24 PM
  #342
The One They Call Dirty's Avatar
Originally Posted by Kraig
When I was following you I had to lift a couple of times as I didn't want to nail you in the rear, like I got Chris Sanchez at the start because I couldn't see through a radio.
Yeah, that sucked lol. It's racing, I don't get upset when something like that happens, since it was definitely not a plow like I got from someone else that race.
On a different note, I'm heavily debating ordering this truck, like a click away lol. I know Kraig's truck looked great a the Showdown, anyone else out there doing well in blinky?
The One They Call Dirty is offline
Old 07-15-2014 | 03:24 AM
  #343
motorfinger's Avatar
This truck is just awesome. I have mine setup like the setup that was posted at initial release with the exception of the shock package. I am running gold rear springs with 27.5 wt oil and Kyosho 4x1.3 pistons in the rear and Orange springs in the front 35 wt oil and 4x1.3 pistons in the front. I am also running the new Orion 100c shorty all of the way back and this truck is "Dialed". I love it in Blinky Stock class. can't wait for the winter to run mod SC in mid motor config.
motorfinger is offline
Old 07-15-2014 | 05:53 AM
  #344
"Ducky"
Thx Ducky,
I'm going to wire it up tonight. I trimmed those tabs, but w the battery all the way back and ESC in front of it you need SUPER long wires to make it work.
I'll take yours and Dom's advice and get the ESC as far under the tower as i can.
thanks guys
Old 07-15-2014 | 05:54 AM
  #345
Originally Posted by dominick i.
Josh,
I'm using the aluminum one from TLR. just need a little shorter ball stud (and some loc-tite) to make the clearance.
