Team C TM4 - Official Release Thread
#526
Ok, I have to ask! What makes you say that U.S. support will be better soon? I've talked to several people who should know the deal over the past few months. I haven't been able to get any kind of answer as far as parts support or even kit availability in the States. It has me very nervous. I own pretty much all Team C vehicles at this point. I am very happy with all of them, especially the TM4. Might be my all-time favorite rc! It's just a really bad feeling when I can't find any parts for any of my cars for months on end.
#528
#529
I have a problem with my center gear - although the gear mesh is fine - the main gear loses some material - I can see a significant amount of dust under the center diff after every run. Is there any aftermarket part available or a compatible main gear/ center diff to try?
#531
Yes it is installed correctly.
#533
First what surface are you running on?
Are you sure its actually dust from the spur? The center diff flings any left over fluid from assembly down against the chassis and then dirt/dust (if you are running on dirt) or I would assume carpet fuzz (if you are running on carpet) sticks in the fluid spot.
Do you check the mesh all the way around the full rotations of the spur and pinion? the gears are never totally round so you can have a perfect mesh in one spot, and a super tight mesh on the other side of the spur, you have to find the happy medium. Also make sure you recheck the full rotation after you tighten the motor mount down, sometimes torquing the mount down changes the mesh.
Have you tried a different pinion? Maybe its not quite the right pitch or has a weird spot in it.
Are you re-adjusting the mesh every run? Otherwise I would think eventually you would loose enough material that it either finds its happy place and stops making dust or you strip the gear completely.
Unless it leads to a stripped spur I dont think it would be anything to worry about really, especially not enough to try and fit another brands diff in there. Some of my 2wd buggies create some dust in the gear covers but it doesn't hurt anything.
#539
I've been running my TM4 in Sydney Australia for some time now - outdoor clay and dirt, low to medium grip tracks.
The car has a loose rear end on power in my opinion.
I seemed to have taken a lot of this away by running the shocks on the rear, adding weight to the rear with the brass option suspension hanger and taking the anti squat out of the rear so running the lowest front and highest rear insert. This for me has settled the rear a lot under power.
I run the centre diff with 100,000 weight oil. Front diff is a lot heavier oil than rear diff as well.
I'm going to try shorter rear camber links this weekend to see what that will do.
#540
