Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 04-18-2014, 08:13 PM
  #8626
rigor's Avatar
Trader Rating: 44 (100%+)
Originally Posted by predu
Yes I read that a couple of weeks ago. You race on high bite,if you need more grip use a softer tire,I am already using mega soft and it's a long ways off. I have driven the car on high bite clay,it's a different animal on a loose track.
Just trying to help. 1 of my tracks is high bite, the other is medium+.
Here's the link to the Facebook B5Nation group.
https://www.facebook.com/groups/1464245550469506/
rigor is offline
Old 04-18-2014, 08:24 PM
  #8627
suby723's Avatar
Trader Rating: 21 (100%+)
B5rm rear arms are soooo last week! You guys must be living under a rock! Its a mod worth testing forsure. Btw getting on b5nation is the ticket if you want the latest and greatest on news, mods and tips.
suby723 is offline
Old 04-18-2014, 08:33 PM
  #8628
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by VegasHB
This front ackerman and wheel bearing thing is really ticking me off. Everyone figured it was the crush ring so that was replaced...set of bearings gone. Went to the hard ackerman inserts to remove some slop and everything was dandy but bearing set #2 toast. Then tonight I went to change my ackerman from 3mm to 2mm. Checked the bearings before disassembly and smooth as butter. Pulled one side apart very carefully, spun the bearings to double check they're free...good, swapped ackerman inserts to the 2/4, put it all back together without yet putting the screw in the axle and boom..same bearings start binding....WTF? Well crap, change the bearings out to new and back to smooth. Half set of bearings toast again.
Did the other side and boom...binding bearings and i'm out of spare bearings...
There's something with the inserts not being perfectly inline thus the axle sits cocked a bit causing uneven wear in the bearings eventually.
And how the....bleep does this happen? Sheered off the inner lip of a "hard" insert on one side...
my kit breaking are still smooth after 4 weeks. I am using the +3 trailing with stock plastics. So i dunno what is going with yours. Some guys say the schelle or avid bearing hold up well
Wildcat1971 is offline
Old 04-18-2014, 08:58 PM
  #8629
gticlay's Avatar
Trader Rating: 14 (100%+)
Plus Rob Bacon/Oldschlracer/whoever...
gticlay is offline
Old 04-18-2014, 09:18 PM
  #8630
aeRayls's Avatar
My bearings have felt gritty when built since day one. It's very frustrating. Pull it apart and it's smooth in my hands, put it together, feels gritty. Bearing isn't toast but it feels that way installed.
Some people have the problem, some don't, some change to the 3 insert and it's gone, some it gets worse lol. Another guy bought different bearings, problem solved. Who knows.
It bothers my OCD to no f***ing end!!! But it doesn't stop me from winning races
aeRayls is offline
Old 04-18-2014, 09:21 PM
  #8631
vito's Avatar
got the losi 22 sold to get the new b 5 kit now off in the am to pick it up
vito is offline
Old 04-18-2014, 09:22 PM
  #8632
predu's Avatar
Thanks, I will get the arms when I go to the track next.
predu is offline
Old 04-19-2014, 12:36 AM
  #8633
mdowney's Avatar
Quick tip for anyone using the 3x8mm set screws in the front caster blocks (which eliminates most of the slop): those little screws strip VERY easily so don't over-tighten and back them out very carefully. If they strip you'll never get that caster block off the hinge pin in one piece. You'll be hacking away at it with the Dremel like I just did.
mdowney is offline
Old 04-19-2014, 04:10 AM
  #8634
Trader Rating: 105 (100%+)
I was thinking that also.. May want to run a longer SS steel 3mm screw or 3mm tap to tap the those holes.
dan-o is offline
Old 04-19-2014, 04:48 AM
  #8635
SS is softer. That only makes the issue worse. But tapping it would be good
Old 04-19-2014, 05:45 AM
  #8636
Enjoy the build Vito!!! Its a great car with lots of potential!!
Oldgearhead is offline
Old 04-19-2014, 06:39 AM
  #8637
racer_guy's Avatar
good lookin out!! so is it worth getting them as far as getting the job done is concerned?
racer_guy is offline
Old 04-19-2014, 06:43 AM
  #8638
Trader Rating: 27 (100%+)
Good tip...you can use one of the longer M3 BHCS screws from the kit to thread the holes first.
langsky is offline
Old 04-19-2014, 06:44 AM
  #8639
They most defininately take the slop out.
langsky is offline
Old 04-19-2014, 07:22 AM
  #8640
I currently race a schumacher KF and have always had a B5m in the back of my head. From the guys that race what have you seen comparing the two and would it be an "upgrade" to switch? I run on indoor ozite offroad track.
Bracer11 is offline
