Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree139Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 02-13-2014, 08:31 AM
  #3376
Rick Hohwart's Avatar
Originally Posted by Holeshot114
Has anyone added any weight to their car for better handling? I feel that it seems to go down the straights a little light on the front end. But, seems a little heavy in the front on jumps.
Discussions about adding weight to the front of the car to improve handling need to start including the servo used. There is a high difference in servo weight and now drivers are starting to use even lighter low-profile servos (in general). For example, the difference between a low profile Airtronics servo and an AE XP servo is more than 3/4 oz.
Adding 1/2 oz (mentioned previously) may not be adding anything at all. If he is using a low profile servo, it may not even be enough to equal another driver's heavy servo vehicle.
Rick Hohwart is offline
Old 02-13-2014, 08:35 AM
  #3377
Captcha's Avatar
You will in durability. The b4.2 is brittle in comparison. I would get the b5 to be honest.
Captcha is offline
Old 02-13-2014, 08:41 AM
  #3378
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Originally Posted by wever75
Ok, thanks for all the responses. I can pick up a FT b4.2 with all the goodies for $150. For my 1st 2wd buggy i don't think I will see a huge difference between the B5 and B4. ( on a personal begginer note )
I would get the b4. The b4.2 factory bling is kinda useless and the car is much more fragile for a new driver.
Wildcat1971 is offline
Old 02-13-2014, 08:46 AM
  #3379
Originally Posted by Grasschopper
Wait what? The stock setup is terrible? I picked up a lap on my previous best with no tuning whatsoever. Am I going to be able to do even more with some tweeks? Really I just thought it was better than the B4 everywhere.
I have to agree with the write up... B5 with box setup when drove hard pushes like a dump truck... I will say with a little tuning tho the B5 is way better!
NickGroves is offline
Old 02-13-2014, 08:51 AM
  #3380
lol, locals are telling me the box setup has massive steering. But we race outdoors
Old 02-13-2014, 08:54 AM
  #3381
Pittsdriver's Avatar
I did experience a push in the corners. I am going to start attacking that issue. How are you guys dealing with the corner push? I changed the ackerman to 3mm and it still pushes.
Pittsdriver is offline
Old 02-13-2014, 08:56 AM
  #3382
gticlay's Avatar
Trader Rating: 14 (100%+)
I haven't added any weight but running a full sized 6040 servo I did have some issues with doing wheelies on our back straight.
gticlay is offline
Old 02-13-2014, 09:03 AM
  #3383
on power or off power push?
Old 02-13-2014, 09:07 AM
  #3384
gticlay's Avatar
B4 and B5 both seem to be a bit of a point and shoot car - massive forward traction with good off power steering. Both of mine have a little bit of on power push compared to my old TLR22 cars. Who knows with the mid...
gticlay is offline
Old 02-13-2014, 09:10 AM
  #3385
Captcha's Avatar
This is gene hickerson running the intech er12 on the exact track I did my comparison on.
https://www.youtube.com/watch?v=R_5F...e_gdata_player
as for on power push my setup changes from stock are following.
Front shocks have 2x1.6 ft tapered pistons, 32.5 ae oil, black springs.
Rear shocks are 2x1.6 ft tapered pistons, 27.5 ae shock oil and kit springs. 24mm ride height all around.
Captcha is offline
Old 02-13-2014, 09:12 AM
  #3386
Tech Legend
Wild Cherry's Avatar
you get to race it yet ?
A 1/2 oz on the front end will cure any on power push & wheelie issues.
Wild Cherry is offline
Old 02-13-2014, 09:19 AM
  #3387
Maybe adjust the suspension first before adding weight?
JiuHaWong is offline
Old 02-13-2014, 09:24 AM
  #3388
ah. I drive corners with off power and shoot it out of the corner. Because if you push off power, they have these things called breaks and they really make the car turn If you want to drive the car on power in the corners, just get the MM car. I drove my MM 22 last weekend and if I was not on the power in the corners, I was facing the wrong way, lol. MM can driven much harder in the corners on power. Mostly because they have crap for rear traction. If you have enough forward traction to wheelie, on power turning will suffer. For me MM was TOOOO much of a good thing, lol. Stiffer rear springs and more limiters in the front should help on power. Of course those changes effect other things, not just steering. weight up front will help keep the wheels down on power, but also make the front sluggish. its all give and take.
Old 02-13-2014, 09:28 AM
  #3389
Tech Legend
Easier just to add the weight and its most effective for a solution.
interested in how you would fix with tuning though.
Old 02-13-2014, 09:30 AM
  #3390
gticlay's Avatar
Definitely something I'll try. I've only run some practice packs through it.
Edit to add: I also am going to put a saddle pack in as I was using a shorty...
gticlay is offline
