Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree139Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 04-05-2016, 06:36 AM
  #26626
AZJP's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Socket
If I had a B5M, and raced there still. I would look into those older 3 gear setups, OR look into Cav's and Rivkins nationals setup.
Where are you at now for setup? Springs/oil/camber links.
Front 1.4x3 32.5 grey flat arms standard links, +1mm inside.
Rear 1.6 30 blue rear motor rams -2 inside +2 on hub
But like I said I've been changing roll centers to find something that works, but the above setup is what I generally have been running.
Mod setup vs stock setup is not even close from what I've found
AZJP is offline
Old 04-05-2016, 06:38 AM
  #26627
AZJP's Avatar
Originally Posted by Wildcat1971
what tires are you running? Slipper eliminator?
Dieseled primes, but have switched to akas but don't have a lot of time on them yet. Schelle slipper almost locked out.
AZJP is offline
Old 04-05-2016, 06:40 AM
  #26628
Pville Stig's Avatar
Originally Posted by BRSracing
word is a new dirt car and a high traction/carpet car
Sounds like the associated version of the YZ2.
Pville Stig is offline
Old 04-05-2016, 06:45 AM
  #26629
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
primes have more grip than smoothies for sure. Which is what I am currently running. You dont find the car too soft with those springs? not tippy? Are you running 4wd fronts?
Wildcat1971 is offline
Old 04-05-2016, 06:46 AM
  #26630
Suspended
Trader Rating: 61 (100%+)
Look below.
I know on the rear I ran the schelle camber block and ran the 2nd inner hole, no washers on it. You had to stiffen the car up a TON to get it to not traction roll and be too touchy.
What toe and anti squat? I would run 3x1, and then negative 5 on the rear hubs.
Socket is offline
Old 04-05-2016, 06:50 AM
  #26631
Suspended
Here is Hump's last 3 gear setup. Note the usage of the schelle rear camber mount.
Socket is offline
Old 04-05-2016, 07:01 AM
  #26632
Trader Rating: 97 (100%+)
Originally Posted by JC8390
Whats with the lay down transmission? Someone give me the dummy version lol.
edit... so after a google search, apparently it just moves the parts down to lower the center of gravity?
Pretty much. But it also moves the motor forward a ways. Which helps balance the car out when its on carpet or turf.
Pinebox is offline
Old 04-05-2016, 07:26 AM
  #26633
AZJP's Avatar
No, 2wd fronts. I am running those springs because the front tires had so much grip, with the front stiffer than the rear it would snap roll.
AZJP is offline
Old 04-05-2016, 07:28 AM
  #26634
AZJP's Avatar
Look below.
3.5 rear toe is too much I would think, would lose a lot of forward bite. What's the advantage of the schelle camber block vs the flipable associated?
AZJP is offline
Old 04-05-2016, 07:35 AM
  #26635
try 4wd front, really smooths out the car.
Old 04-05-2016, 08:10 AM
  #26636
AZJP's Avatar
Isn't that illegal?
AZJP is offline
Old 04-05-2016, 08:18 AM
  #26637
AZJP's Avatar
Look below.
3:1
AZJP is offline
Old 04-05-2016, 08:20 AM
  #26638
AZJP's Avatar
Originally Posted by bds81175
If you are fighting traction rolling take out some droop. Its possibly the most effective way to eliminate traction rolling without destroying the handling everywhere else on the track.
So more limiters is what you're saying?
AZJP is offline
Old 04-05-2016, 08:21 AM
  #26639
Isn't that illegal?
unless it has changed in the last couple weeks....almost everyone at srs runs 4wd fronts. Just something to try. Personally, I run stiffer springs than you. But softer is fine and gains steering, just too edgy for me.
Old 04-05-2016, 08:26 AM
  #26640
AZJP's Avatar
It's not edgy if you make other changes to support it. I'm gonna probably run Thursday with how the car is now then spend Friday and Saturday testing some ideas.
AZJP is offline
