Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree138Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-15-2016, 03:36 PM
  #26221
Flip boy's Avatar
Originally Posted by xxx123
I have not moved my hub yet. But i will try next time.
I have stock rear plastic hub that has 2 holes (inside and outside); i had inside hole and moved to outside. After i moved to outside; spins even more.
For more stability you want the link shorter, keep in mind your shock spring piston oil setup needs to be in the ball park based on track conditions. Inside hole on the camber link(shock tower) try the inside hole on the hub with the 3 hole insert. Tires 85 to 90% of battle.
Flip boy is offline
Old 03-15-2016, 03:41 PM
  #26222
Trader Rating: 22 (100%+)
Thanks i will keep this in mind, However, my plastic rear hub has 2 holes only....i picked he one that is closest to the inside tho
xxx123 is offline
Old 03-15-2016, 03:58 PM
  #26223
Flip boy's Avatar
You can buy those inserts, i rarely used the two hole majority was the 3hole insert until i bought hubs
Flip boy is offline
Old 03-15-2016, 05:45 PM
  #26224
Trader Rating: 68 (100%+)
I don't want to use pucks because, well I really don't have a good reason, lol. I keep searching for a rationalization but I just want to win without them so other racers will not think they are a prerequisite to have a fast car.
todb is offline
Old 03-15-2016, 07:58 PM
  #26225
Phil Trotta's Avatar
The pucks system remove 4 grams per bone and 16 gram on outdrives for total of 24 grams. This in using Exotek spur and eliminator make for a killer drivetrain
The cut gears are also worth it as well ...imo
Does require different setup than stock bones. Car will rotate harder on power
Phil Trotta is offline
Old 03-16-2016, 07:30 AM
  #26226
What racing wing do you guys prefer in regards to bang for the buck? ive heard a few guys at my track recommend the serpent buggy wing.
caffeine357 is offline
Old 03-16-2016, 07:40 AM
  #26227
jmcelroy42's Avatar
The ProLine Trifecta is pretty durable. However I like the design of the Upgrade RC Vortex wing.
jmcelroy42 is offline
Old 03-16-2016, 07:45 AM
  #26228
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Honestly, the stock wing is the best. It's strong, great down force and inexpensive.
Jmuck69 is offline
Old 03-16-2016, 09:35 AM
  #26229
Originally Posted by tc5 man
With it that dry a B5 would do better .
Originally Posted by nmdesertracer
I would say the b5 would be better!
Thanks for your replies Even though I'd like to hear different. On thought I had:
The B5R has more weight on the rear axle (RA), the B5M FL should have nearly the same (or most likely) a little more weight. So the added weight would be partially at the RA. So if a (just a example) B5R weighs 1500 and the B5M FL 1650 it could be possible that both share (nearly) the same load on the rear axle. So the difference would be the longer distance between the wheels (dont know the english term) and that most of the mass (motor) is nearer to the center of rotation (which I think is good).
Are my thoughts wrong? What do I miss (as you can see I am looking for reasons that are pro B5M )
And ragarding the track: It's my first year there and I cant tell if the track is most likely to be that dry (like dusty dry) ore more likely wet sticky clay.
man1ac is offline
Old 03-16-2016, 11:16 AM
  #26230
yeah The stock wings are rather cheap for a 2 packs on tower hobbies, maybe ill just stock up on those.
Old 03-16-2016, 12:26 PM
  #26231
I was faced with a hard time cutting those curves with the one included
Keith B is offline
Old 03-16-2016, 12:44 PM
  #26232
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
dremel
Matt Trimmings is offline
Old 03-16-2016, 01:03 PM
  #26233
Kalio's Avatar
The stock wing never lasts very long for me. The sides of the wing seem to break the most easily. The Proline Trifecta wing lasts a long time though. What I started doing was use the Proline wing most of the time and use the stock wing only for racing (due to slight weight savings).
Kalio is offline
Old 03-16-2016, 01:05 PM
  #26234
Flip boy's Avatar
The kit wing is awesome, if your somewhat wealthy then i like the jconcepts precut
Flip boy is offline
Old 03-16-2016, 01:17 PM
  #26235
DennisNyholm's Avatar
I've been using my stock wing since I built the car and it is hanging in there. I spend a lot of time on my lid too. My finnisher body came with a 2 pack of wings so I think I am good for a little while.
DennisNyholm is offline
