Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 03-08-2016, 01:39 PM
  #26026
JC8390's Avatar
Originally Posted by DennisNyholm
Anyone know of a place we can get the cut gears and mip top shaft? I'd love to save on shipping! And caged thrust and ceramic bearings...
Originally Posted by kjohnsiii
Check out the first post there's good stuff to check out there.
Doubt it... I think speedy RC is about the only game for shaved gears and they don't sell anything else.
JC8390 is offline
Old 03-08-2016, 01:49 PM
  #26027
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Nope, CB's Custom makes cut gears also.
http://www.shop.cbscustomrc.com/
thecman26 is offline
Old 03-08-2016, 04:04 PM
  #26028
Originally Posted by Matt Trimmings
I have only shortened the wire on my transponder. I'm a fan of heat shrink to keep everything looking nice and clean. Looks great!
I do the same thing. I pop the pins out of the clip, place the wires back and forth over each other then put heat shrink on it. Take a photo of the order of the pins in the clip.
I thought about shortening them and even have the extra pins and clips to do so. I decided to keep them the original length for resale and in case I wanted to use it in another application.
Attached Thumbnails Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-image.jpg
Just2much19 is offline
Old 03-08-2016, 04:27 PM
  #26029
JAE
Trader Rating: 30 (100%+)
Waterfall fan mount question: Anyone use these? Prime or Shapeways? Also, there are different sizes? Any tips on how much temps are down and weight addition much appreciated. Thanks!
JAE is offline
Old 03-08-2016, 05:01 PM
  #26030
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
I'm not a huge fan (lol) of the waterfall mounts available...You pretty much have to run the Finnisher body, they dont work well with the silencer bodies. So I made my own, I hollowed out the stock waterfall and picked up the Schumacher KF2 fan mount. Mounted it to the cradle and attached a 25mm fan. When i initially started running with a fan it dropped temps roughly 25º.
Attached Thumbnails Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-image.jpg   Team Associated RC10 B5m Mid-Motor & Rear Motor Thread-fanmount2.jpg
Matt Trimmings is offline
Old 03-08-2016, 05:15 PM
  #26031
That came out great, nice work!
Old 03-08-2016, 05:49 PM
  #26032
JAE
Hx - I'm a noob, so anything to lower temps serves a dual function of allowing more runtime when practicing turning laps. Did you just dremel it out? Any issues with durability?
JAE is offline
Old 03-08-2016, 06:01 PM
  #26033
Yes. Dremeled out the stock waterfall and mounted the fan mount with a pair of xrings in between the cradle and mount so it has a little shock protection.
Old 03-08-2016, 07:16 PM
  #26034
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
nice! can we see a pic of the wiring for the fan please?
kjohnsiii is offline
Old 03-08-2016, 07:55 PM
  #26035
It just runs along the cradle and plugs into the spare channel on the rx.
Old 03-08-2016, 08:22 PM
  #26036
kjohnsiii's Avatar
looking good! thanks
Old 03-08-2016, 08:41 PM
  #26037
DennisNyholm's Avatar
I got a waterfall mount and use a finisher body. Just installed it recently and was bashing around in the street in 45 degree weather. Motor never got hotter than 75 degrees. I will be bringing it to the track in a few days to see how it works indoor and putting some actual stress on the motor.
I'm way under weight so it didn't bother me adding it as I would think the benefits outweigh the weight penalty. Planning on jumping up a gear or two on the pinion as well to see how it handles it.
DennisNyholm is offline
Old 03-08-2016, 10:44 PM
  #26038
JAE
Default Waterfall
You should sell these. I would buy one from you. Imagine a lot of people out there that don't get the waterfall mount because they don't want to deal with either a new body or they like the AE body....
JAE is offline
Old 03-08-2016, 11:23 PM
  #26039
All you need to do is Dremel the waterfall and solder the plug onto a fan. Amain sells everything you need.
Old 03-09-2016, 12:32 AM
  #26040
Thanks for all the tips fellas!
Just getting back into the hobby in a serious way. I've always previously built kits with allen keys. Picked up a 1.5MM and 2MM hex driver from the hobby shop. Couldn't believe the difference in how my hands feel after a few steps, as well as how tight I can get things. I thought that the chassis plates just wouldn't sit perfectly flush with the chassis when screwed together. I went back over them with the hex driver and it's mint.
Good tools make a difference, whodathink it
intercede007 is offline
