Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 02-24-2016, 08:41 AM
  #25681
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally Posted by itsdavedubail
Any one do the B5 to B5M conversion? Anything i need to be aware of? I couldn't seem to find a thread on here about it. Thanks!
If you already have the conversion kit just download the B5M manual from the Team Associated website and it should have all the info you need. Car goes together very well so you shouldn't have any issues.
Randy Caster is offline
Old 02-24-2016, 08:57 AM
  #25682
DennisNyholm's Avatar
I have some tower hobbies ecash expiring soon and I'm thinking if something to get. Has the overall experience for the MIP puck system been positive for 17.5? I am also thinking of getting a full size servo to replace my futaba 9550 but I can't seem to find anything decent on towers site that has similar performance. I'll probably just stick with the futaba and add some weights to the front of the car, but I didn't know if there were other alternatives from tower (no savox) that might be worthwhile to consider.
DennisNyholm is offline
Old 02-24-2016, 08:58 AM
  #25683
Thanks! i was getting a little nervous with some of the reviews on Amain. One said the diff case was changed and the bearings for the B5 will not fit the new B5M one.
itsdavedubail is offline
Old 02-24-2016, 09:08 AM
  #25684
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
That is potentially still true depending on if the B5m conversion kits include either the old 4 gear case (which will utilize your top shaft) or if it now includes the new v2 top shaft and bearings so it will mate with the new 4 gear case.
Matt Trimmings is offline
Old 02-24-2016, 09:12 AM
  #25685
i guess we'll see Friday when it gets here!
Old 02-24-2016, 09:19 AM
  #25686
Silverstonev8's Avatar
Maybe a Reedy 1206? Little faster more torque and 21.5g heavier...
Silverstonev8 is offline
Old 02-24-2016, 09:24 AM
  #25687
It would be a few bucks more on top of the conversion but you should definitely consider the 3 gear transmission setup. The performance of the 3 gear is excellent, I've never driven a 2wd buggy that feels as good as my B5M does.
Old 02-24-2016, 11:00 AM
  #25688
Has anyone ever tried installing rubber grommets in their wing? I went to the hardware store this morning looking for wing mounting ideas and this is what I came up with. I'm using the original wing mount but filed the posts down past the pin-holes and drilled the posts to accept a 3mm screw. Seems very solid, yet forgiving.
Gearhead82 is offline
Old 02-24-2016, 11:05 AM
  #25689
your right for the price you cannot go wrong! Then ill have a choice.
Old 02-24-2016, 11:43 AM
  #25690
is there a difference in handling between 25 degrees bulkhead+5 caster block insert and 30 degrees bulkhead and 0 caster block?
Overall angle is the same.
Toyman_R is offline
Old 02-24-2016, 11:47 AM
  #25691
Seems like a nice servo! Not sure if I should do that or the mip pucks though. Which would give more benefit overall. Leaning toward pucks but want to ask the experts here
Old 02-24-2016, 11:51 AM
  #25692
but one of the newer manuals (eg B5M lite) as some info in the original manual is outdated
Toyman_R is offline
Old 02-24-2016, 02:51 PM
  #25693
Jakesterama's Avatar
Trader Rating: 68 (100%+)
I'm running the AC RC Gear 3 gear LCG with the fan waterfall and I'm wondering if anyone knows which bodies fit? I know the JConcepts Finisher fits, because that is what I am running, but I need a new body. I'm wondering if the Proline Predator or the JConcepts S2 Worlds will fit with enough clearance for a 10mm thick fan on the LCG waterfall.
Jakesterama is offline
Old 02-24-2016, 03:46 PM
  #25694
Do you guys run aluminum pinion gears or steel?
Old 02-24-2016, 03:56 PM
  #25695
I use the S2 but it's tight so I cannot see it fitting if you have the fan.
Just2much19 is offline
