Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
What have you broken on your B5M?
I know I can't predict every failure but I'm wondering if there are any parts I should keep around to minimize down time at the track? I'm just starting to race and local shops aren't super well stocked with B5M stuff yet so I'm somewhat tied to the online shops for now.
Same here. Bulkhead and front shock pivot ball/eyelet were damaged after a crash (my fault though). Hinge pin was a little bent as well. Other than that I've had no other breaks.
Anyone know if Team Associated is going to release the B5M to B5MCE kit to other stores or will it just be sold through them? Thanks
http://www.amainhobbies.com/rc-cars-...90002c/p486628
http://www3.towerhobbies.com/cgi-bin...&I=LXFXSE&P=ML
I do have to say though, these cars are pretty bullet proof. The amount if hard crashes I have had would have put my old touring cars into multiple pieces. It really is amazing how tough they are. Even without a full width front bumper protecting the arms.
Looks like Tower and AMain both carry them. Both currently out of stock though.
Trader Rating: 53 (100%+)
http://images.amain.com/images/large/tkp/tkpc8006.jpg
I use this on lots of things. Works great.
Guys using the 3 gear mid motor what shock springs are you using on hardpacked clay with dust on the outside lines ? Right now im using Gray/F White/R with stock pistons and 32.5 W . Although i haven't tried out different tread tires for that condition only Typos, Dirtwebs which work better when the track has moist to it.
White 32.5 front green 27.5 rear
