Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 02-15-2016, 03:15 PM
  #25561
Originally Posted by Just2much19
Jason did a YouTube video on this, you can search for it on YouTube or google. He says that with the larger rims you get less walking around and is better for high bite tracks as opposed to the smaller rims where you get some more cushion for bumps. The newer rims are easier and take less glue.
It all comes down to preference and availability. Also with such a small difference I am sure t would be hard to tell the difference but then again I haven't tried them, just going off what I've read and heard.
Thanks!!! I'll check out the video
JP187 is offline
Old 02-15-2016, 03:16 PM
  #25562
Originally Posted by tc5 man
If it's the Front wheels actually for me i could tell a difrence the 2.4 wheels and tires smoothed the steering out more side bite . The 2.2 Fronts more steering feel and turn in better on bumps .
2.2 rears and 2.4 only difference I could tell with them is the 2.2 have more side bite/ handle bumps stay glued better .
2.4 rears are lighter traction wise to me it's less but still grip good bad on bumps though and stating glued but I fixed that issue .
Thanks for the Info!!
JP187 is offline
Old 02-15-2016, 08:14 PM
  #25563
Trader Rating: 515 (100%+)
The 2.4s are for smoother tracks. That's really what they are designed for. When the track is smooth they work great. The only issue that I've seen with them is the side walls ripping/tearing on high bite surfaces. They are also about 10 grams lighter per wheel/tire.
QDRHRSE is offline
Old 02-15-2016, 10:02 PM
  #25564
Whats the preference on battery for this car? Square pack or shorty ?
JP187 is offline
Old 02-15-2016, 10:15 PM
  #25565
tc5 man's Avatar
Most run Shorty packs including myself for indoor tracks .
tc5 man is offline
Old 02-16-2016, 09:35 PM
  #25566
I would definitely go with a shorty. If you happen to go with a low rider trans it will work with that as well. Also with the shorty you can position it forward to improve weight distribution as well as being lighter. Many companies have them cheap including SMC, dinogylipos and plenty more.
Just2much19 is offline
Old 02-16-2016, 09:38 PM
  #25567
Cerevo's Avatar
New to the buggy world, having a t5m though the b5m seems like what I will want when the time comes to get one.
Thanks for all the good info in this thread!
Cerevo is offline
Old 02-16-2016, 09:48 PM
  #25568
Welcome and I would keep an eye on the for sale section, there are a lot of complete and already modded out B5Ms for a good price.
Old 02-17-2016, 05:01 AM
  #25569
DennisNyholm's Avatar
Silly question, but if I mix 25 wt oil and 30 wt oil 50:50, will it be 27.5 wt oil? I have both and want to try 27.5.
DennisNyholm is offline
Old 02-17-2016, 05:09 AM
  #25570
Jerm13's Avatar
Trader Rating: 36 (100%+)
Ish... math wise yes, viscosity wise not so easy. You can try it and see if you like the desired result, or just buy a $3 bottle.
There was somewhere on here ( RCTech, not this thread) that had a link to a site that would tell you how to mix what with what to get a desired weight. Try google. Thats about all I can offer.
Jerm13 is offline
Old 02-17-2016, 05:22 AM
  #25571
Thanks. Actually found the site and it says 52:48, so very close to 50:50. I couldn't find 27.5 in stock which is what got me to thinking.
Old 02-17-2016, 05:45 AM
  #25572
Are you supposed to grease the dog bones on the diff side? The manual didn't mention it. Seems like some lube would be beneficial but I could also see it attracting dirt and causing a problem.
Gearhead82 is offline
Old 02-17-2016, 06:00 AM
  #25573
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Not necessary as it will attract dirt. Should spin freely without any lube.
thecman26 is offline
Old 02-17-2016, 06:32 AM
  #25574
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Some people use wax chain lube, as it does not attract dirt.
Wildcat1971 is offline
Old 02-17-2016, 07:15 AM
  #25575
Thanks, I ordered a couple from SMC yesterday
JP187 is offline
