Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 11-16-2015, 08:51 AM
  #23896
lbckevin's Avatar
Trader Rating: 107 (99%+)
It will clear the J concepts Finnisher body
lbckevin is offline
Old 11-16-2015, 11:50 AM
  #23897
one of the guys at our track runs the stock body with the fan mount waterfall and he has cut the back 3 inches or so off clear across and cut both sides out I think it looks good better than the finisher. finisher may perform well and have room but all I see when I look at mine is a Volvo station wagon. I don run that body anymore I am going to let my kid run it lol.
jslider is offline
Old 11-16-2015, 12:02 PM
  #23898
Can anyone tell me what 0 anti squat is used for? I'm just curious if less anti squat gives u most traction? Thanks
DIRT DIGGER is offline
Old 11-16-2015, 01:16 PM
  #23899
Jerm13's Avatar
Trader Rating: 36 (100%+)
It can... Less anti squat will allow the rear end to "squat" down under acceleration. Its the weight shifting to the rear allows this to happen which could provide you with more traction under power..
Jerm13 is offline
Old 11-16-2015, 03:35 PM
  #23900
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Reducing anti-squat does 4 basic things
1) Increases rear-end squat, on-throttle (less on-throttle steering)
2) Increases weight shift to the front of the buggy, off-throttle (better off-throttle steering)
3) Reduces rear-end roll resistance, which gives more rear traction / less steering, in the corners
4) Should be more stable on a bumpy track
(edit: and technically, the buggy SHOULD jump more nose down...(I think) but I'm not typically paying attention to that when I play with A.S.)
Cpt.America is offline
Old 11-16-2015, 05:06 PM
  #23901
Trader Rating: 15 (100%+)
Originally Posted by Bob Barry
drove the Factory Lite for the first time this weekend. Made me remember why I loved my B5M before The car is just soooo good.
I don't have good 17.5 batteries yet and I know my esc and motor tune was off and I still managed to qualify 4th and be within .5 on the fast lap. On the stock setup with only the alum C and D blocks and Avid slipper
btw, 1522g weight (because I know all the cool kids need to know)
I do have one question. I bought the waterfall that has the fan mount in it. The stock body doesn't quite clear it right. For the guys who are running that setup, what body are you running?
The Sweep body fits. Pro-line Phantom does not.
mx836 is offline
Old 11-16-2015, 06:16 PM
  #23902
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
How does a body not fit a waterfall mounted fan?
All that should be way below the transmission. Hence clearance shouldn't be an issue. I ran one and the body was nowhere near it. With the stock body though.
Just curious.
thecman26 is offline
Old 11-16-2015, 08:31 PM
  #23903
Just curious.
It's quite simple really. Since you are mounting a fan on the waterfall, the fan is going to stick out further forward than if there was no fan there. Crazy, I know. They are cab forward bodies that sweep down behind the cab, then back up over the waterfall and transmission. The Sweep body fits over the fan. Pro-line Phantom doesn't.
mx836 is offline
Old 11-16-2015, 08:36 PM
  #23904
gabc's Avatar
Default Shock stand offs
May I know which shock stand offs are good with the b5m stock shock caps? Will like to minimise the slop. Thanks!
gabc is offline
Old 11-16-2015, 10:14 PM
  #23905
Nat Maniac's Avatar
I have the waterfall fan brace from shapeways and both finisher and proline phantom bodies fit without the need for any modifications.
Nat Maniac is offline
Old 11-17-2015, 03:00 AM
  #23906
Wink
You can use the ST Racing bushing set, comes in 3 anodized colors. I love the play with the composite material though
Keith B is offline
Old 11-17-2015, 03:33 AM
  #23907
gabc's Avatar
Thanks Keith! Just curious, why do you like the play on the stock stand offs?
gabc is offline
Old 11-17-2015, 03:39 AM
  #23908
Motorman007's Avatar
Trader Rating: 89 (100%+)
Can you please post some pics sir?
Motorman007 is offline
Old 11-17-2015, 04:26 AM
  #23909
Volition's Avatar
On the weekend I noticed a lot of slop in my steering. Traced it back to the servo arm moving. Took it out and found the screw was loosened. I have a Protek aluminum servo horn and pt a washer on and some purple threadlock.
In my next race I had my fastest lap & time on that track. The next two races my pace dropped back again and noted the servo arm was a bit sloppy again.
Was it a fluke, how important is a bit of slop in steering. When I got home I ordered a star washer and will lock it down. Blue threadlock too.
I've become paranoid about steering slop and want your opinions on 3 things;
1) how important is eliminating steering slop.
2) exotek make a specific AE 10th scale aluminum arm, is it any good.
3) the jconcepts centering servo mount is this a useful bit of kit or just bling. Does the servo move with stock mounting?
Volition is offline
Old 11-17-2015, 05:06 AM
  #23910
The AC RC waterfall printed by shapeways or a different one? I have the AC RC mount and my Phantom doesn't come close to fitting.
mx836 is offline
