Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Moderator
Hahaha....the car is too good to stay away!
Being a touring car guy, I am one of the only guys I know of at my track that run my battery strap as loose as possible. I like it to be there "just in case" so I can't actually loose it in a bigger crash, but I don't want the battery to be held down tight enough to actually inhibit the chassis from flexing across the center.
Now, if you like LESS chassis flex, considering the battery is down the middle of the chassis and not down one side like a TC... clamping it down tighter will certainly accomplish that. In that case, what matters isn't the fact that you are clamping down the chassis, but that it is down the middle and not down one side affecting chassis flex differently left than right.
With all the talk of battery straps wouldn't the old style/system similar to the original Rc10 using a cap head screw with a hole through the head for a body pin be the best and most consistent way to strap in a battery? I think I just aged myself. lol
For carpet off-road whats the best lay out, shorty stock or shorty inline?
As for layouts, this isn't video games, there isn't one answer that is the end-all be-all.
I recommend you try both, and then make the choice based on lap times. You'll get 100 different answers here. Only you know what feel you want, on the internet we can only guess.
Anyone have a good method for taking the packs into the Lite Chassis. The extra milling seems to effect contact patch a bit.
Where do u cut the cradle? Is there any other spots u are cutting also? Thanks
Question, the v2 shock pistons, I see they will not work with the 5m lite's shock shafts, I guess you need the v2 shafts as well. But has anyone of you just drilled the center hole out of the v2 pistons to fit the old shafts?
I would not trust my drill skills to get it perfectly centered. Just get the v2 shafts
We'll race until its starts to snow or rain. We're in SOCAL and we race into the teens. I thought you East Coast guys were supposed to be use to cold weather?
