Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Who do you contact for a defective kit part? On my newest B5M lite one of the stub axles isn't machined deep enough for the cv shaft to go in far enough to push the pin though the barrel.
does anyone know where i can get a "c" brass arm mount? cant find one anywhere
I normally just call the associated phone number and get on with support, tell them whats wrong. They usually take down your info and then send you a new one.
Hi guys.
What's the go on venting 1/10 2wd tyres. Yes or no. Or in particular conditions.
Just picked a set of black hex's for the front and rear of my b5. For some reason the rear hex's are to small to go over the axles. Seems like they would fit the old b4 axles. Has there been any issues with these.. Ordered a new set from my local hobby shop to see if it was just that pack..
Wayne
So tell us your expected track conditions and many will make recommendations from their experience.
You will get all sorts of answers. What we can all hopefully agree on is that you will need holes some where in your wheel/tire and that depends on your track conditions. Standard hole locations are in wheels, tire sidewall or tire tread.
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
Super Moderator
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Trader Rating: 31 (100%+)
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
I personally vent both the tire and the rim, 2 holes each. Tires..sometimes in the middle, sometimes one hole to the outside of the tread, one hole to the inside. All depends on my mood
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
Obviously this is only on my B5m/B5m lite. My other cars, completely different scenario, and requires posting in those specific car threads.
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
please note heavy sarcasm.
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
I ordered the B5M lite for my second kit (Just finished a SC5M.) Are most people running this in stock class or mod? Is there a general consensus on how to set the trailing axe inserts, rear hub link or bulkhead angle?
Super Moderator
The kit 1.6 piston 32.5 oil front and rear isn't the norm at my track, but I built my lite that way just to test it compared to the set up on old B5m, and the handling was really close. Actually better in some areas. No need to get 'crazy' from the kit set up on the car...IMO
