Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Nice. I'm gonna stop by for a bit tonight. It's been a while since I've driven lol. Well see if I can even get into the 16s lol
I race on a huge 1/8th track on some weekends then small 10th tracks otherwise. Very different.Randy Pike from Tekin recommended I try around 7.9 fdr for the small track. I got the RPM motor. I worked it out for a 72 spur and then the pinion wouldn't reach. So was hoping someone had a table somewhere. To save me the annoyance of changing pinions and Spurs not knowing if they'll fit.
I suppose if I stick to the Spurs you recommend I'll work it out pretty quickly. Thanks.
For those using the X-factory chassis, have you made any changes in lowering shock oil and/or softer springs to compensate for the significant drop in overall car weight?
anyone have input on which spektrum servo works in the b5? i got the new 6240 but it will not work because of the wire location.
I'd look at savox servos. I've never used one, always ran spektrum, but my next servo will be a savox black edition. Never used savox for the sole reason of the ugly orange aluminum. Now they have the same servos with black aluminum.
Thanks for the reply. I run Mod with the current Brent Thielke club racing setup, which I like for our large tacky/semi-tacky track. I'll give a few setups a try with the lighter chassis and report back. If anyone else is running mod with the x-factory chassis and has thoughts, I'd love to hear them. thanks
I run the xfactory chassis with 27.5 wt oil front and 25 wt rear green springs all the way around it works great
