Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree138Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 08-12-2015, 12:09 PM
  #22141
onefast8's Avatar
Trader Rating: 41 (100%+)
Anyone know how the mip eco top shaft lines up with CB cut gears?
http://www.amain.com/rc-cars/mip-17....p15080/p449867
It says it has less contact and just wondering if the actual teeth are narrower to one side or center? I'm just afraid if its off to one side there wont be enough tooth contact area...
Edit: running mm 3gear if it matters.
onefast8 is offline
Old 08-12-2015, 12:10 PM
  #22142
carcrazy699's Avatar
Trader Rating: 49 (100%+)
I am interested in the setup. Sounds just like my track. The car does push and is a bit loose coming out of the corners.
Please post up for us or fill out a setup sheet and post it!
carcrazy699 is offline
Old 08-12-2015, 05:13 PM
  #22143
So I broke in my diff but never got it to stop feeling gritty. I tightened the diff to the point where i could not longer move the left wheel by hand (while holding the right tire and spur). I alternated holding one wheel while giving it a bit of throttle. It felt the same as it did before I started and I still could not turn the left tire by hand while holding the spur and opposite tire. I tested the slipper by holding both wheels and it sounded like the diff barked. I kept tightening the diff several times in 1/8 increments, breaking it in, testing the slipper in between each and so far it still sounds like its barking.
I don't know how far I should tighten it because its really close to being tightened all the way and yet it still sounds like its slipping... Been doing it for several hours now....
Fanatic01 is offline
Old 08-12-2015, 06:16 PM
  #22144
DID YOU WATCH THE VIDEO ON 1ST PAGE, IT WORKS AWSOME DID MINE FIRST TIME AND IT WAS BUTTER SMOOTH WITH ALL BOX PARTS
jslider is offline
Old 08-12-2015, 06:52 PM
  #22145
So today I took all the bearings out of my car and took the rubber seals off and used a RPM bearing blaster to clean them out. There was a lot of grease in each one and they wouldn't spin for long when testing them before. I took the ones out of the transmission also and did a full cleaning of it and used the graphite power and Avid Slip bearing oil and put it all together and WOW what a difference. It spins so easy and smooth now. I am hoping this helps with motor temps and giving me the low end punch I need to!
Old 08-12-2015, 07:05 PM
  #22146
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Cpt.America is offline
Old 08-12-2015, 07:11 PM
  #22147
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
T-Work’s have released this line of shock bushings for Team Associated RC10 B5/B5M 1/10th buggy. Made from hard coated 7075-T6 aluminum they come in a set of 4 and are a direct replacement for the kit versions.
Mckune Design have released their new simple Low Centre of Gravity shorty weight plate. The plates are made from super thin .75mm thick brushed stainless steel, yet still weigh 25 grams each. They will fit under any 2S shorty LiPo and can be stacked for additional weight.
RCBuddha is offline
Old 08-12-2015, 07:16 PM
  #22148
Wow that's really nice! I have been looking at new shock bushings for mine. Mostly for the looks and longevity
Old 08-12-2015, 07:32 PM
  #22149
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I use the avid shock bushings. I like the black with silver etching
Wildcat1971 is offline
Old 08-12-2015, 07:39 PM
  #22150
yxiaocheng's Avatar
Trader Rating: 18 (100%+)
Hi guys. I am new to off-road racing. Just got a B5M and want to set it up. What would be a good gear ratio? I am running 17.5 Stock on a medium sized clay indoor track. And what about the shock oil? Thanks for any suggestions.
yxiaocheng is offline
Old 08-12-2015, 08:04 PM
  #22151
You can get some really good feedback from the folks in this forum, the trouble is they can only give you ballpark guesstimations on the size of your track, how rough the surface is and what would be "best".
Your best bet is asking folks that have their cars dialed in at the track you will be running at. They have done all the trial and error for you for the surface you will be running on, the gear ratio that works for them in 17.5 (this I found will still require some tweaking as everyone's driving style differs ever so slightly and how you want that power to hit is pretty important).
I would get the car ready and hit the track, pick the folks brain you see running good lines and their car seems dialed, rotates well, has good jumping manners and seems to be dialed in already. Most of these will be happy to share their setups, rarely do I find some one unwilling to help me out at the track I run at.
Fasttrak is offline
Old 08-12-2015, 08:19 PM
  #22152
Trader Rating: 515 (100%+)
Depends on the type of 17.5. 69/31-32 is probably an ok place to start for almost any 17.5 but might not be ideal for your track. Crack open the manual. AEs manual setups are pretty good.
QDRHRSE is offline
Old 08-12-2015, 08:43 PM
  #22153
Suspended
So I broke in my diff but...
I'll just leave this here.
That is the bfast break in method. Follow it exactly.
Mantis Toboggan is offline
Old 08-12-2015, 09:49 PM
  #22154
I did my diff exactly like the manual said when I built my car but it seems a tad to tight still. I am going to try the bfast way and see if there is a difference.
Old 08-12-2015, 10:01 PM
  #22155
ChadB.'s Avatar
Trader Rating: 21 (100%+)
I was wondering if any of you knew what the differences were between the B5m vs. B5r rear arms? Has anyone tried the B5M arms on their rear-motor buggy?
ChadB. is offline
