Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 06-06-2015, 10:27 PM
  #21151
3de
3de's Avatar
Thumbs up
Originally Posted by VegasHB
Anyone making a better plastic puck than the oranges? Feel like I have to change my pucks after every 3 rounds of racing in mod with an 8.5. They really don't hold up at all for mod.
Okay, so shiny it is I guess.. And then sounds like the pucks need a little grease?
3de is offline
Old 06-07-2015, 07:28 AM
  #21152
loloscorsa's Avatar
Hey guys, my local circuit has loose soil with low grip, I wonder if the b5m work well or if the ideal car for this area would be a b5 (rear).
Thank you!
loloscorsa is offline
Old 06-07-2015, 07:43 AM
  #21153
Suspended
Trader Rating: 61 (100%+)
Originally Posted by bizarrefish
I had to use 30x69 as my 72 spur had not arrived in time, it's why I was careful with the running today. The motor was warm to the touch and measured between 100 and 115.
I wouldn't go jumping leaps and bounds to change gearing if you're crashing a lot - however I would look into gearing up, and continue to keep an eye on temps.
Is the car massively easier to drive with the 17.5?
Socket is offline
Old 06-07-2015, 07:44 AM
  #21154
Suspended
Thank you!
Go back a page and read.
Socket is offline
Old 06-07-2015, 07:46 AM
  #21155
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
Thank you!
we had a whole discussion on this a page or 2 back.
Wildcat1971 is offline
Old 06-07-2015, 07:57 AM
  #21156
Wasn't crashing that much at all really, over shot a couple of corners on longer straights initially and just some hard landings on all four wheels that felt it bottomed a little. Increased the drag brake and adjusted the diff a touch (very minor tweaks) to assist with cornering.
Will check out recent setups and to compare.
A lot easier to drive thanks, will get lots of practice under me in stock first.
Looking to get a set of tires for asphalt so I can setup some cones and practice outside. JC white compounds appear to be best suited to that.
bizarrefish is offline
Old 06-07-2015, 08:02 AM
  #21157
proline makes a street tires. I forget the name, but that would probably be your best bet. I think they are taller so watch your gearing and temps. the street can be hard on motors
Old 06-07-2015, 08:08 AM
  #21158
Trader Rating: 23 (100%+)
I have over 30 runs on my orginal orange pucks on high grip conditions, I use motorcycle chain wax lube on the pucks, seems to be working, I also clean them after each track day.
Rhett McNair is offline
Old 06-07-2015, 08:27 AM
  #21159
mschumi101's Avatar
Trader Rating: 30 (100%+)
Proline Dirt Hawg tires are for pavement and bashing. They are M2 compound which is their Medium/hard compound. The front tires they make are for both 2 and 4wd buggies, but still fit and work on 2wd front rims. I know Amain has them listed under 4wd in the tire section, but the bag says its for all buggies.
mschumi101 is offline
Old 06-07-2015, 01:11 PM
  #21160
BRSracing's Avatar
Trader Rating: 67 (100%+)
The worlds warm up track looked boring, and left me even more uninterested in the worlds race this year. Did TLR go to the worlds? I did not see any of their drivers in the results I seen. Offroad should be on dirt in my opinion. Much more interested in the ROAR nats over the worlds.
BRSracing is offline
Old 06-07-2015, 02:02 PM
  #21161
tony montana's Avatar
Trader Rating: 76 (100%+)
Anyone know how to get more steering off and on power with the b5m lite. Running the correct tires for the track, the regular b5m's and of course my serpent car have way more steering
tony montana is offline
Old 06-07-2015, 03:22 PM
  #21162
crazy nick's Avatar
Trader Rating: 27 (100%+)
For those of you not on b5nation fb page ��
crazy nick is offline
Old 06-07-2015, 03:38 PM
  #21163
Jake S's Avatar
Trader Rating: 67 (93%+)
it was the japan racing organization's choice to make this layout tame... scotty said on live rc that the worlds layout will have many more jumps.
tlr didnt send any drivers for the warmup race... but jconcepts page shows maifield arriving.
Jake S is offline
Old 06-07-2015, 05:20 PM
  #21164
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Searching for more on power steering myself(w/lite). Just threw on the gullwing arms and tower,hoping that will help. Should be able to make some laps with it wed.
KAWIDAD is offline
Old 06-07-2015, 05:38 PM
  #21165
STLNLST's Avatar
Trader Rating: 32 (100%+)
I could have placed on that layout.....lol
STLNLST is offline
