Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree141Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 05-05-2015, 07:00 PM
  #20581
mschumi101's Avatar
Trader Rating: 30 (100%+)
Originally Posted by flintTRDTC
They are the ASC1733 heavy duty shims. Meant for the B44 series.
Thanks! I used to have some, but sold them all with my B44! whoops. Makes sense I couldn't find them under B5...
mschumi101 is offline
Old 05-05-2015, 07:13 PM
  #20582
steelers82's Avatar
does anybody know if you still need to put black diff grease in the schelle thrust bearing?
steelers82 is offline
Old 05-05-2015, 07:51 PM
  #20583
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Yes, always run black grease.
Jmuck69 is offline
Old 05-05-2015, 07:54 PM
  #20584
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
This will work better imo....plus they come in different thicknesses. The B44 series still uses std bearings where the new stuff uses metric...its close though.
http://www.amain.com/rc-cars/yokomo-...-s100s/p242340
Matt Trimmings is offline
Old 05-05-2015, 07:56 PM
  #20585
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I used these. pretty much any of them will work
http://www.amain.com/rc-cars/search?cID=&s=td310033
Wildcat1971 is offline
Old 05-05-2015, 10:22 PM
  #20586
What's the most motor you can run in a 3 gear factory lite and not compromise longevity too much? Can it handle a 13.5? A 10.5?
Noize is offline
Old 05-05-2015, 10:23 PM
  #20587
3srcracing's Avatar
Trader Rating: 29 (100%+)
Turned break EPA up to 80%, and went from 1mm to 1.5mm on the front shock tower, dialed. Still needs a little work, but definitely is WAY faster then my Kyosho.
Just a little loose going into the corners, but might just be me over driving it.
3srcracing is offline
Old 05-05-2015, 10:34 PM
  #20588
pink_sleeve's Avatar
Trader Rating: 221 (100%+)
Compromise the longevity of what? I'm running mine in mod class with a 7.5 and it's better then my 4 gear normal car was by far
pink_sleeve is offline
Old 05-05-2015, 10:35 PM
  #20589
HBRob's Avatar
Trader Rating: 61 (100%+)
Personally cant think of anything, beyond the chassis that is less than what is a B5M standard and would take consideration. 3 gear isn't necessarily weaker. Just don't crash, chassis will be fine.
HBRob is offline
Old 05-05-2015, 10:44 PM
  #20590
Thanks. It's in my 9 year old daughter's car with a Reedy 17.5. She's learning control really well, and is complaining about power when we're practicing outside, but I don't want her to put it into the wall at the carpet track, so I think I'm going to make her stick with this motor.
Noize is offline
Old 05-06-2015, 02:47 AM
  #20591
MiCk B's Avatar
Hi,
What are people experiences with the 91608 +4mm Arm Mount.
Is it a improvement in all track conditions, or just for high traction tracks.
MiCk B. :-)
MiCk B is offline
Old 05-06-2015, 03:21 AM
  #20592
MiG77's Avatar
Originally Posted by Wildcat1971
14g under the rack was always good in my B5. Also, use the smallest pinion and spur you can to move the motor forward and pucks remove about 30 grams from rear of the car.
I am doing similar with my B5. Im not adding any weight to front tought. Just taking it away from rear and I run battery forward position (square pack). Also as Im running mod class total weight is not that huge issue to me. Im still running less than 1600g of total weight.
MiG77 is offline
Old 05-06-2015, 06:25 AM
  #20593
Suspended
What surface? I could imagine something like a 3.5 on carpet or asphalt would be pretty tough on the car.
Socket is offline
Old 05-06-2015, 08:09 AM
  #20594
Alright just got a fat e- cash check from tower. If you guys had to get one spring set each for front and rear, what would you go with? Mostly racing on high- bite clay (critters raceway NJ). Oh and I'm running a 10.5 in the Lite which has white springs.
Hooplah is offline
Old 05-06-2015, 08:52 AM
  #20595
davidfast's Avatar
Trader Rating: 24 (100%+)
By sets do you mean pairs? Go Grey then.
Or by sets do you mean the AE sets? Go with the medium sets.
davidfast is offline
