Team Associated RC10 B5m Mid-Motor & Rear Motor Thread >
Like Tree138Likes
    Hide Wikipost
Old 04-22-2024, 12:09 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Old 01-31-2015, 02:22 PM
  #17986
What transmission is Drescher running?
C.Borgia is offline
Old 01-31-2015, 02:43 PM
  #17987
out of curiosity, because being i dont race, i dont know these things....
i get this is geared towards stock racing, but for a person running mod, which of the two would they buy?? .....Cause if they would also buy this new one and just add weight if they wanted, wouldnt it make the "regular" b5m obsolete going foward??...
Which ones gonna get the factory team treatment when the time comes, both??
Is there any reason for someone to now buy the "regular" b5m instead??
pardon me if this sounds ridiculous.....im just trying to figure out what the purpose of the "regular" b5m is going forward. (different transmissions etc)
NickTheGreek is offline
Old 01-31-2015, 02:52 PM
  #17988
Davidka's Avatar
Trader Rating: 86 (100%+)
Yokomo's? ;-)
Notice he's also running a front wing.
Davidka is offline
Old 01-31-2015, 03:22 PM
  #17989
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wink
Maybe a version of this one
JDM_DOHC_SiR is offline
Old 01-31-2015, 03:34 PM
  #17990
mmobee1's Avatar
Thanks Mick, will give them options a go
Mike
mmobee1 is offline
Old 01-31-2015, 03:54 PM
  #17991
mmobee1's Avatar
Default Battery weights
Question for you guys?
Just been weighing the following:
2s 4500mah cased shorty 152g
2s 3200mah cased stick pack 184g
2s 5000mah normal stick 252g
2s 5100mah cased saddle packs 262g
2s 6000mah cased stick pack 298g
I appreciate the sticks won't go in a B5, but curious to have feed back, as when I see posts of adding extra weight in various positions. Also would different mah battery options in saddles, shorties or squares require different pack setting, damping and / or spring settings for the same track set-up.
Many Thanks,
Mike
mmobee1 is offline
Old 01-31-2015, 04:38 PM
  #17992
Logi Maker's Avatar
Trader Rating: 56 (100%+)
Originally Posted by vito
ae gear box or mi one help I cant drop 150 right now
You answered your own question...
Logi Maker is offline
Old 01-31-2015, 05:20 PM
  #17993
mschumi101's Avatar
Trader Rating: 30 (100%+)
Where are those CAD drawings from? Looks good though. Though there aren't any good angles of Drescher's car in the former post, in the 2nd picture it looks as though you can see a spur/slipper on the left hand side of the car, run without a gear cover presumably.
mschumi101 is offline
Old 01-31-2015, 05:29 PM
  #17994
Originally Posted by Davidka
Yokomo's? ;-)
Front wing, interesting eh? Some people do run them.
Dave H is offline
Old 01-31-2015, 05:33 PM
  #17995
Davidka's Avatar
I used to run one back in the late 80's. Aerodynamic devices work much better when they're in unobstructed air.
Davidka is offline
Old 01-31-2015, 07:25 PM
  #17996
PnchoPwr's Avatar
Trader Rating: 19 (100%+)
This is going to sound like a complete noob question, but, I must ask. What front tower is for the rear car, and which for the mid car? I had the front of my car torn apart, and had to get up and leave the workbench for a bit. When I came back, I forgot which tower was which. Thanks for your help.
PnchoPwr is offline
Old 01-31-2015, 07:38 PM
  #17997
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
Default Fan, Fan, Fan your boat, gently down the stream....
http://www.shapeways.com/product/U9M...ionId=43516079
http://www.shapeways.com/product/K9K...ionId=40673346
http://www.shapeways.com/product/LYG...ionId=40612170
RCBuddha is offline
Old 01-31-2015, 07:41 PM
  #17998
PnchoPwr's Avatar
Is it stronger than the white waterfall fan mount that is available?
PnchoPwr is offline
Old 01-31-2015, 07:42 PM
  #17999
RCBuddha's Avatar
No clue.
RCBuddha is offline
Old 01-31-2015, 07:45 PM
  #18000
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I am running the first one. Ran it for the first time tonight. It seems pretty stout. I showed my spare to a guy that ran the ADI ones, and he thought mine seemed better maid. You do need to use 3mm screws to hold the fan on though. dropped my temps by about 25 degrees.
Wildcat1971 is offline
