Team Associated B5 Thread
#363
For the price of the RB6 you can have both B5's without the headache of taking a car apart to swap the motor configuration around if you want to try each.
#365
R/C Tech Elite Member
So we spent 199.99 for a conversion, and we can get a new B5 for 260?
If this pricing is now correct, those are very fair prices. Im thinking they wont be the factory team kit but if they are like the 4x4 sc truck when it was released then have an upgrade kit then that might me ok.
#367
If you dont like MM buy the RM? Dual use cars as far as MM and RM are a waste of R&D. You take away from each platform using the same chassis. You need a chassis for each motor config to get the most out of the car. The 22 and RB6 are a cluster to mount electronics in using the same chassis. AE is right on track.
#368
if its a factory team kit for 260.00 then there isnt one person who can complain about that. so what its two cars, its two cars for a reason. there isnt a platform that AE likes that suits both, so to bring us the best they gave us two cars for the price of an RB6. I dont see the problem, I personally will have a B5 RM for stock and a B5M for mod and for our outdoor season ill use the RM car for mod.
#370
Anyone who thinks a Centro or a 4.2 is not competitive or obsolete is kidding themselves.
#371
Everything else is standard rtr type. No titanium turnbuckles, no cf battery strap, no aluminum rear hubs, no CVA, etc.
B5 FEATURES: Chassis: Composite tub type
Drive: Rear wheel
Transmission:
Shocks: Factory Team 12mm Big Bore hard anodized aluminum
Differentials: Ball type with lightweight outdrives
Wheels: Plastic white dish type front, 0.94" (24mm) wide, 2.4"
(61mm) diameter, rear 1.5" (38mm) wide, 2.4" (61mm) diameter
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Drive: Rear wheel
Transmission:
chassis
his is the 1/10 scale electric powered, radio controlled,
Associated RC10 B4.2 Factory Team off-road buggy kit.
FEATURES: Chassis: +8mm B4 composite tub type
Drive: Two wheel with CVA drive shafts with pin retainer clips with
steel center-drilled front axles
Transmission: 2.6:1 laydown type, high-torque capacity with VTS
slipper clutch (variable torque, multi-plate slipper with 3 drive
surfaces)
Ball Bearings: Full set, 14 rubber sealed
Shocks: Factory Team 12mm Big Bore hard anodized aluminum with TiN
"Gold" 3mm shock shafts
Shock Towers: Optimized for the Big Bore shock
Motor Plate: Factory Team blue aluminum milled construction
Spur Gear: Plastic, 81 tooth, 48 pitch
Wheels: Plastic yellow dish type front, 0.94" (24mm) wide, 2.4"
Wheel Hexes: Factory Team front and rear 12mm blue aluminum clamping
type
Body: ProLine Bulldog
chassis
Toe-In: Fully adjustable, with titanium turnbuckles, toe-in describes
the angle of the front tires as viewed from the top
Suspension: Optimized for use with LiPo batteries, mounts for 4°,
3.5°, 3°, and 2.5° rear toe
Turnbuckles: Factory Team blue anodized titanium turnbuckles
Front axles: Steel center drilled
Steering: Factory Team aluminum bellcrank,
Servo saver: Built-in with aluminum servo saver bolt and heavy duty
spring
Battery Strap: Carbon fiber with blue aluminum thumb screws
surfaces)
type
chassis
spring
#373
Super Moderator
Trader Rating: 31 (100%+)
Tower "wording" gets edited a lot as they get more info. So I'm hoping it's released as a "Factory Team" car..Would be dumb not to IMO. Shocks are the biggest factory team option on all their cars, and this one clearly has them. I would assume it will have all the other "bling" as well.
Doesn't seem to come with any tires..that's a good thing IMO.
Whatever your view on AE quality is. I don't think at that price point (well under $300) we're going to see a change in that department.
#375
I doubt AE would use dog bones in a "team" kit. Composite instead of aluminum or steel CVD's maybe. Also, I thought there was no difference between a CVA and CVD? CVD being a trademark of MIP.
