2S LiPo pack quality
#31
I really wish there was a better industry standard for testing batteries. I like amain and my order should be arriving in two days, but I will NEVER pay their prices for lipo batteries. I'm sure everyone's seen the big squid battery comparison where gens ace cleans house every time. These "expensive" battery's are simply "licensed" battery's from the same manufactures which means that the anatomy of the pack isn't crafted by the company with the sticker on the case (in most cases). I've yet to see a battery where the seller actually post true data about the particular cell in question. Prove to your customer that you actually assemble this battery. I've used the same 4 nanos for 2 years now two of them are showing a little swelling and one has a melted -5mm. The melting of the cases has very little to do with the packs themselves quality. Heat is generated by resistance, resistance in this situation is cause by improper fitment of the actual male bullet connector. If your bullet slides in easly it's not making good connection. Buy cheaper batteries and don't fall victim to the man!!! I like what smc has to offer, the best of both worlds.
#32
The C ratings on packs are all over the place, so for the price of a pack buy an IR Meter and measure things yourself.
I can't buy every brand, but I've got a few Turnigy Nanotech and a few SMC, and SMC consistently have less resistance (higher C) new, and after 30+ charges. I have a strip of red electrical tape on each pack and just tick off each discharge so I can track packs degrading over time.
I didn't have any noticeable performance issues with the Turnigy lipos... until I bought a Tekno SCT410. The Nanotechs bounce off the LVC more times before they're dead (the SMC's tend to hit the LVC once, or twice, then dead: which is better as they're holding higher voltage under load). I lean towards SMC for my Tekno, but I'd gladly tell a new hobbiest to save $$$ and buy Nanotechs if they're not pushing around a heavy SCT.
Next packs I buy will be SPC or Team Great Hobbies (LHS rebrand). Gens Ace are interesting, but more difficult to ship to Canada. Don't be afraid to try new brands!
#33
I'll give a recommendation for the SPC packs. Great support and very knowledgeable. I bought some of the 5400 50C 2s packs. I was told when I called with some questions that the cells were Japanese mil spec cells. Some of his other batteries use good quality ISO 9000 company China cells. The batteries have performed flawlessly, although they are not under a tremendous strain (2wd SCT).
Chevis
Chevis
#34
There are for sure better quality packs than others. If your looking for the best pack, Which to me is the one that makes the most power, then the RevTech packs are some of the best. For most offroad racing a little more power doesn't matter but if you race stock or super stock on a large higher bite track and can use the power a good pack is gonna help. Don't use the packs that the Amain worlds guys are using necessarily as they are using mod motors and dont need that extra power as they can just motor up, Ie Reedy packs. The top brands of packs are Trinity Sting, RevTech, SMC, OHP, EA and a few others that run well. Cycle packs on a GFX charger and you can see a good pack from a mediocre pack. If your having problems with inboard bullets then your more than likely using a very low end pack.
#35
Out of curiosity are the Racers Edge packs any good? My LHS is offering these as high end packs when I asked the same question, looking for high end packs.
#37
5mm bullets are a big step in lipos and should be standard. Electrons flow on the surface of copper conductors, not "threw". More surface area equals less resistance. Which leads me to the crazy clams made by the battery industry 100c on a 7000mah pack is 70amps!! It is very hard for my to consider this as being factual simply due to the fact that electric "code" says you must use at least #3 stranded copper conductor!! That's about the size of your middle finger!!! Not to mention the burst C rating they claim. Madness.
#38
#39
Marty, can u plz explain how 70amps is possible using 10 gauge wire? Thanks.
#40
You have to use higher gauge wire just for a 20Amp wall socket in your house. How the hell are they claiming this tiny ESC can pump through 160A continuous, and correct me if I'm wrong but something like a 100C rated battery at 5,500mah ... doesn't that equal 5.5*100 = 550Amp output capacity?
#41
V=IR
It is easier to understand those output claims when you use the equation V=IR.
Voltage = Amps * Resistance
For example, households run off of about 120V. Therefore, depending on the gauge wire used through out the home, only a certain amount of amperage is available usually around 12A. This is casued by a lot of resistance due to the lengths of wire used as well as the type of wire.
Now compared to our stranded wire in Rc, solid wire found in our household will carry less current in comparison because it has less surface area.
Additionally, our cars running on lower voltage with batteries that have lower internal resistance which will yield higher current. This makes those large Amp outputs accurate but only as accurate as the manufacturer makes them. At this point, it comes down to whether or not the output was fudged.
Hope this helps!
Hope this helps!
#42
I've searched everywhere but haven't found anything "definitive" on which brand LiPos are the best.
I'm looking at picking up a couple 2S LiPo saddle packs for a new 1/10 4WD kit I'm building, and tossing in all the highest-end components.
What're some of the best LiPo's available? Are there are factual tests that prove a 100C battery is actually capable of sustained 100C discharge rates for example, or is it all just brand-loyalty and trusting the specs are accurate?
Don't get fooled by those who say you can buy better ...
They are incorrect and I just save you mass bucks , just compare their price to whoever you can ...
