Timing and Reversed Motors?
When running a motor in reverse direction in cars like the XB4 and many others... is it best to leave the can at 0 degrees and make all timing adjustments through the ESC? It's my understanding that whatever timing you have set on your can.... you will actually have negative timing once you reverse motor direction. Basically.....
10 on can + 20 on esc = 10 degrees timing
10 on can + 10 on esc = No timing
20 on can + 10 on esc = -10 degrees
I was hoping some more knowledgable people could confirm this. I would assume it's best to leave at 0 on can and make all adjustments through esc. I tried searching but couldn't find the right answers. It seems some people flip their diffs and keep normal rotation but that isn't possible on all cars.
