Locking the diff on a 22t
Pro - never have to rebuild the diff
Cons - no traction or steering
If want to lock your ball diff to try it out.. but not hurt any thing and be able to go back to the ball diff this is what you do.
1. Buy a bicycle intertube repair kit.
2. Using your diff rings cut out 2 sections of the patch material to the same size as the diff rings.
3. Put diff together replacing diff rings with the pieces you cut out. (Make sure there are no Diff balls in the gear)
Works very well and will last forever. You will wear out CVDs and CVD pins. I used this method on my 4wd buggy in the front.
