Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 09-15-2014, 07:37 PM
  #946
Diggity's Avatar
Trader Rating: 33 (100%+)
Default ZX6 Carbon Fibre Battery Strap
We have just released our ZX6 battery strap.
Please check out our website for more info -
http://www.diggitydesigns.com/products_Kyosho_ZX6.html
Diggity is offline
Old 09-17-2014, 06:47 PM
  #947
vikingen's Avatar
Trader Rating: 29 (100%+)
^ ordered, despite the postage costing more than the item itself
vikingen is offline
Old 09-17-2014, 07:37 PM
  #948
Anybody working on a 3 diff setup for this car?
Rickybob is offline
Old 09-18-2014, 03:49 AM
  #949
crack80k's Avatar
Zylux,
I notice you are using the KO Propo BSX2 One10 response but with a Futaba radio. Nice build and paint job btw, my ZX6 is at the servo saver stage, loving the experience so far.
I tried this servo with my Futaba 4pl and the only way it would work was to have the radio and ESC powered on and then unplug the servo from the receiver and then replug it. Bit annoying and cast a doubt over the rest of the compatibility and functionality. Will return it and go the Futaba BLS551.
How have you fared? Con
crack80k is offline
Old 09-18-2014, 03:06 PM
  #950
Gayosaka's Avatar
Any feedback on that layout? I'm thinking about trying that on my old FS2.
Gayosaka is offline
Old 09-18-2014, 03:15 PM
  #951
Gayosaka's Avatar
Originally Posted by crack80k
Zylux,
I have the same problem with a RSX1 One10. It works when you switch response to normal. Just remember to turn off and on the radio after switching, or the 4PL stays on "high response".
Agreed, that's a bit annoying for such an expensive and quality servo
Gayosaka is offline
Old 09-18-2014, 03:58 PM
  #952
Trader Rating: 357 (100%+)
I didn't say it but was thinking samething.
jmoneym is offline
Old 09-18-2014, 04:22 PM
  #953
JarrodP's Avatar
Awesome CF parts made by Bezerk Rc in Australia. Find them on Facebook.
JarrodP is offline
Old 09-18-2014, 04:40 PM
  #954
JarrodP's Avatar
JarrodP is offline
Old 09-18-2014, 04:44 PM
  #955
Nice work
jmoneym is offline
Old 09-18-2014, 04:49 PM
  #956
aloksatoor's Avatar
Trader Rating: 43 (100%+)
superb cf. How different does it handle on dirt?
aloksatoor is offline
Old 09-18-2014, 04:51 PM
  #957
vr6cj's Avatar
Trader Rating: 124 (100%+)
it works awesome. Put new life back in my old zx5fs. U should do it
vr6cj is offline
Old 09-18-2014, 05:21 PM
  #958
JarrodP's Avatar
I race on carpet and it's great.. That's the flex topdeck so it still has some movement but won't eject the drive shafts(not that I had that happen with the plastic braces) plus it's about 40ish grams lighter.. cant remember exactly.
The notch taken out of the battery strap is handy too.
JarrodP is offline
Old 09-18-2014, 09:23 PM
  #959
Trader Rating: 57 (97%+)
I know the answer is somewher ein here but I can't seem to find it...
Will the ZX-5 Bulldog body fit? I want to try and get all my cars to have the bulldog proline look. I need to get them shipped to my painter so I wouldn't even be able to test fit.
CaseyDDR is offline
Old 09-18-2014, 09:38 PM
  #960
All those pieces of CF are 40g lighter than their combined plastic equivilents?! That's some awesome looking CF! How thick are the suspension towers?
WagwanBumba is offline
