Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 07-02-2014, 01:59 PM
  #466
vikingen's Avatar
Trader Rating: 29 (100%+)
Originally Posted by joecool
Are the steering knuckles going to rub on the front arms like they did on the zx5? When we ran more droop in the front end of the zx5 a dremel was needed shave the arm slightly for clearance to turn the wheels full lock. I hated that about the old car.
I'm yet to start building my zx6, but looking at the instructions there is no mention of this needing to be done, unlike in the zx5 instructions
vikingen is offline
Old 07-02-2014, 02:18 PM
  #467
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Zylux
I was going to order a new steering servo for this buggy and having only had an RB6 2WD I'm not sure if I need a full-size servo for a 4WD or if a shorty will cut it?
I use a KO Propo RSX one10 Response in the RB6 and it's great. Would use the same servo in the ZX6 if I could as it's lighter than a regular size servo and would allow me to swap between cars if needed. But does the 4WD put a LOT more stress on the steering servo? Should I be buying a beefier servo?
I ran shorty in my 4wd car for a while, BLS551, could not notice any significant difference between that and the 451. Having a servo saver will help as well of course!
aloksatoor is offline
Old 07-02-2014, 03:59 PM
  #468
KalEl63's Avatar
If the rear suspension blocks are like the optional RB6 ones then D in/D out would be 6 degrees of Toe. D in/ D in would be 3deg as would D out/ D out.
The front pills are the same as the RB6 but the rear are bigger ones marked A thru to F
I should have thought to Google the ZX5 as I got my answer with this chart
Side note I'm going to try a Spektrum S6070 servo first (only because I have one NIB already)
KalEl63 is offline
Old 07-03-2014, 02:29 PM
  #469
joecool's Avatar
Trader Rating: 22 (100%+)
Default Near completion
Well I got my kit today and nearly finished the roller. It's an awesome build so far. The quality is awesome. Here is a pic of it.
joecool is offline
Old 07-03-2014, 03:58 PM
  #470
KalEl63's Avatar
Very nice Joe, I did do some more building last night but just haven't had a chance to get the pics up.
I will do some more building tonight and hopefully get it to rolling stage.
Joe how have you found the chassis flex? I am surprised how much there is
KalEl63 is offline
Old 07-03-2014, 04:13 PM
  #471
vikingen's Avatar
starting my build tonight and im torn over which config to try first
vikingen is offline
Old 07-03-2014, 05:53 PM
  #472
joecool's Avatar
Yeah the chassis flexes a lot more than I thought when I pulled it from the box. Once all the braces are mounted its pretty much how you think it should be.
joecool is offline
Old 07-04-2014, 05:57 AM
  #473
KalEl63's Avatar
Ok here is where I am up to with the build.
I have a lot more pics than this but didn’t want to blow the thread out with another 20 odd photos.
I will get to the body over the weekend and once the black wheels arrive I’ll do the final pictures then.
I must say this car went together well and I’ve had a blast building it and yes I have not put the sway bars on as I need to go buy another 3mm drill bit as I can’t find the one I have.
KalEl63 is offline
Old 07-04-2014, 08:00 AM
  #474
mourinho's Avatar
Trader Rating: 46 (100%+)
What's with the foam over all the ball studs? Ive seen it on others cars, but dont recall seeing it in a manual.
mourinho is offline
Old 07-04-2014, 08:40 AM
  #475
Trader Rating: 68 (100%+)
It's supposed to keep the dirt out, but after 1 run they will start to tear apart
Speedychris22 is offline
Old 07-04-2014, 08:51 AM
  #476
mourinho's Avatar
Ahh ok, thanks.
mourinho is offline
Old 07-04-2014, 09:09 AM
  #477
K_King's Avatar
Trader Rating: 47 (100%+)
They are using the other color anodizing, interesting.
K_King is offline
Old 07-04-2014, 12:18 PM
  #478
Is it possible to change to gear diffs?
Magnus F is offline
Old 07-04-2014, 02:19 PM
  #479
Holmberg418's Avatar
Yes. Gear diffs are available for the car from kyosho
Holmberg418 is offline
Old 07-04-2014, 02:56 PM
  #480
justpoet's Avatar
Trader Rating: 16 (100%+)
Are the spindles and spindle carriers beefier than on the zx5 by a significant amount?
justpoet is offline
